#945212 by gumshoe
23 Jul 2018, 16:54
There is, but it’s a bit of a red herring.
While there’s a fast-track queue for the initial passport and boarding pass check, it just dumps you into the same (normally very long) queue for the scanners as everybody else.
If you have TSA Pre+ on the other hand (which comes with Global Entry), there is a dedicated and genuinely fast-track security channel.
#945213 by Spill
23 Jul 2018, 16:58
gumshoe wrote:There is, but it’s a bit of a red herring.
There’s a fast-track queue for the TSA agent who checks your passport and boarding pass, but then you just feed into the same (normally very long) queue for security itself as everybody else.
If you have TSA Pre+ on the other hand (which comes with Global Entry), there is a dedicated and genuinely fast track security queue.
Thanks for this. Just a followup question - How do I find the "fast track" queue? and can UC passengers use it?
#945214 by gumshoe
23 Jul 2018, 17:09
Yes, it’s available for UC and FC Gold passengers who should have “Sky Priority” marked on their boarding pass.
I believe the priority queue is the far left of the 4 or 6 queues for Gates 70-129 security, near the lifts that take you up to the Hyatt hotel - on the right of the map here: https://orlandoairports.net/getting-around-mco/
But I repeat - it is nothing to get excited about, it is nowhere near what we’ve come to expect from Fast-Track security at LHR or LGW. It’s more like MAN, but a lot worse.
#945217 by itisme
23 Jul 2018, 17:41
DO leave on time indeed for the security at MCO. Even if you have prio it doesn't mean much at Orlando. Sometimes it's so badly organised and long queues it could cause people to miss flights. It can take very long there sometimes. You might get lucky but i had some horrible experiences there.
#945362 by Traveller2
30 Jul 2018, 10:01
I have no status whatsoever with Virgin but the last two times I've flown home from MCO, I've had TSA Pre Clearance on my boarding pass! Result! Idon't have a clue as to why but it was a big perk.
#945366 by EstelleB
30 Jul 2018, 12:41
Traveller2 - I think it must be random. Last year my daughter had it but not the rest of us, so if they would give it to a child without a parent, I can only assume that it is randomly assigned!
