#948467 by AlphaOmegaJG
04 Feb 2019, 03:44
I'm flying VS46 JFK to LHR on Tuesday 5th February.
Flight out here was very quiet, about half seats in PE empty and 2 or 3 in UC empty also so wondering what the load is like on the way back to see if it'd be feasible to upgrade from PE to UC. (On that note, is it possible to upgrade from a PE reward fare to UC?)
Load check would be much appreciated if someone is able to take a look.
#948469 by mitchja
04 Feb 2019, 12:07
Welcome to V-Flyer :)
TBH, loads checks are no use when you are on reward fares as they don’t include reward availability.
You can only upgrade a reward fare using more miles and there will need to be reward availability in Upper as well.
(Having just checked, there is currently an Upper reward fare available on your VS46 fight)
You can’t upgrade a reward fare using cash.
#948474 by AlphaOmegaJG
04 Feb 2019, 14:24
mitchja wrote:You can’t upgrade a reward fare using cash.
Thanks both for the load check and the info. Is this true even when turning up at the airport on the day?
I recall reading in a different thread that at that point you may be able to upgrade a reward fare using cash but perhaps I was mistaken.
