#950323 by SlimpyJones
08 May 2019, 10:45
If you have GE, then not long at all. Your biggest bottleneck will be re-entering security. Of which you have three options:
1. Head back upstairs to departures through "normal" JFK security, where you can take advantage of TSA-Pre which I assume you will have, and then use the bus to get to T2.
2. Remain downstairs in arrivals and go to the little-known security checkpoint on the arrivals level, it's at the far end of the terminal (i.e. exit customs and turn left). You'll come out in T4 landside and you can take the Jitney to T2. If you're in a hurry I would try this.
3. Head up to the Airtrain and go to T2, and clear security there. I've no idea if they have TSA-Pre that side. If you have the luxury of a little time you could try this option :-)
For any option I would leave your luggage (if you have any) with the connections desk after customs in T4.
#950331 by mitchja
08 May 2019, 14:50
Give yourself around 30 minutes when connecting using the Jitney between T4 & T2. It departs T4 next to gate B18 and arrives T2 next to gate C60.
More details about the Jitney can be found here
The actual bus ride takes <5 minutes but there can sometime be a bit of a wait for the bus.
Once you have collected your luggage from your arriving International flight as you enter the arrivals hall, turn left where you will then see the transfer desks. After the transfer desk keep heading left towards the exit but then turn left again where you will see the small security entrance. If this is closed you will be directed upstarts to departures to use the standard T4 departure security.
Once through security you then head to gate B18 and down the escalator to Jitney waiting area.
Do keep your eye on your departing DL flight though as DL can and do often changes terminals at JFK.
