#950386 by daviis
11 May 2019, 13:35
Afternoon All !
When looking for VS reward seats I can get them up on the app ( single day at a time) but when I go onto the website to look at flexible dates it doesn’t let me select the miles option at all.
Does anyone have any suggestions???
TIA
#950387 by Splatt
11 May 2019, 13:42
I continually have this problem. Drives me mad. Are you using an Apple device as it appears to be a common factor among colleagues. I’ve raised it several times but nothing fixed yet.
#950388 by daviis
11 May 2019, 13:47
Splatt wrote:I continually have this problem. Drives me mad. Are you using an Apple device as it appears to be a common factor among colleagues. I’ve raised it several times but nothing fixed yet.
Hello Splatt.
Thank for the reply. Yes iPad and iPhone. Good old Virgin IT strikes again >-(
#950390 by AlsirAl
11 May 2019, 17:24
I find the easiest way is to find the flights on rewardflightfinder.com and then use single dates on virgin site.
Virgin IT leave a lot to be desired with bits like this, the BA search functionality is a lot better imo (but then BA have can’t seem to keep people’s data safe :-O swings and roundabouts I guess :-P )
#950394 by daviis
11 May 2019, 23:15
AlsirAl wrote:I find the easiest way is to find the flights on rewardflightfinder.com and then use single dates on virgin site.
The problem with rewardflightfinder is that is only works for VS flights, it doesn’t work with indirect mixed VS/Delta flights.
#950395 by AlsirAl
12 May 2019, 08:10
Ah apologies then, thought you were only after VS rewards.
