#950456 by pem
16 May 2019, 08:40
Hello all
Just booked PE flights with KLM which are code share using Virgin planes
£584 for return PE from LGW to MCO in September 2019 a considerable saving
Can someone confirm I check in at the Virgin desks at LGW and MCO
#950459 by tontybear
16 May 2019, 10:44
Yes check in with VS as the operating carrier
KL don't fly from either LGW and MCO
#950477 by Kraken
17 May 2019, 18:04
I got some very cheap Upper Class seats to MCO on an AF codeshare flight (so the same joint venture as the KLM one). All operated by Virgin direct MAN-MCO. The itinerary clearly states "Check in with Virgin Atlantic". Also if you logon to Manage My Booking on Virgin with the AF PNR, it briefly flashed up the underlying VS PNR - write it down quick!
It seems that there are some very good fares to be had under this AF-KLM joint venture on codeshare flights. Just a case of finding the right days and striking whilst the iron is hot.
#950489 by pem
18 May 2019, 22:38
hi
On hotudeals someone posted Expedia were listing cheap PE seats at end of September KLM with codeshare on Virgin planes
On expedia I entered end September date, PE class, LGW to MCO and was able to preselect PE seats during booking process
KLM flights came up way, way cheaper than Virgin
Checking my flight details on KLM website it showed Economy seats (as KLM do not have PE) I immediately emailed out KLM customer services and they confirmed I have PE seats (as per the seat numbers I had selected)
