#952204 by ColOrd
14 Sep 2019, 20:28
Bit confused as you cant travel in Upper to either Cancun or Paris as Virgin don't operate there.
If you are using your miles to book those sectors on Delta (I think Mexico only has "Domestic" First rather than business) in their Delta One cabin, then no you wouldn't be able to as access to the CH is only on routes that VS and DL share. That may change for Paris with the new JV including Air France
#952207 by tontybear
15 Sep 2019, 00:13
I think I deciphered your flights but the answer would be no because the CH is only if you are flying either Virgin or Delta on a TATL flight to the U.K..
Delta One to Paris would get you the DL sky club at T4. If it was on AF then it would be the AF lounge in T1
not sure about JFK - CUN as that can be seen as a domestic flight and so may not get lounge access without status. If you did it would be the sky club. It may not even be the Delta One product - check before you book to avoid disappointment. delta One is not the same as domestic F or Business.
