#956641 by David
17 Jul 2020, 10:41
There used to be a trick where you changed a bit of the address bar and were able to see all your previous flights. I'm sure I took a copy but can't find it and would like to check just how many flights I've had on the 747's. Since the update, this doesn't work now (along with a few other things ..... )
Anybody know of a way to find this data ?
thanks
#956646 by TimCrawley
17 Jul 2020, 20:51
Hi David,
Before the highly praised website upgrade (!) there was a way to get all your old history as you mentioned - see end of this post - but as you say that doesn't work any longer.
I know some folks had problems initially on the new website even going back more than 3 months meaning they had to choose the custom date range but then be sparing in the date range (keeping the gap between start and end date under 6 months) but that still only got you back 1 or was it 2 years?
It seems to work properly now though on date ranges but only allow a rolling maximum of 3 years so nothing earlier than 17/07/2017 as of today, then by tomorrow that will become 18/07/2017 etcetera. I even tried manually typing in earlier dates but that just gives an error :-(
Sorry I don't have the answer for you but perhaps someone has found a clever workaround on the new website like there was for the old website or it may be something Flying Club themselves can extract and email for you at least a year or two further back than the seemingly rigid rolling 3 years as I'm sure I saw someone post on here in last year or so they had got that from FC to help resolve a TP query they had.
Best of luck,
Tim
The tip from International Hitman that I had seen, but not acted on, before to see your history from year dot:
"There is actually a way to see all your history --- Log into your FC account, on Your Account Summary page scroll down to "Last 5 transactions" and press the Update button beside it --- URL line changes and middle section will say statementSelection=0 change the 0 to an 8 and Hey Presto -- your statement from the beginning of time"
#956647 by David
19 Jul 2020, 11:33
Thanks Tim
Yes, I noticed it now seems to go back 3 years - I don't think it originally did. I have kept a rough date of flights but the original system used to give you exact dates and flight numbers. I'm sure somewhere i did a screen grab before they switched it off but am struggling to find it.
It was only to try and see how many 747 flights I managed to take. I know i had only 2 with BA but I reckon around 94 with Virgin. There seems slim to none chance that I will make it to 100 now :-(
Thanks again
Users browsing this forum: Fuzzy14 and 28 guests
