#961146 by Speedbird1994
20 Mar 2023, 11:44
Hello! I read an article on another site from a few years ago, saying that VS had reduced the numbers of crew on their A330s from 12 to 10. Is this still true? I was wondering how many cabin crew VS have on each of their aircraft types (A330s/A350s Leisure and Premium configs/B787s) and how many work in each cabin? Thank you in advance for your answers!
#961151 by ColOrd
22 Mar 2023, 00:45
I’m not sure that’s indicative of the covid cuts which have never been reinstated.
My understanding now
787/330(both 300 and 900)
1 FSM and 3 Crew in J
1 CSS and 4 crew in W/Y for a total of 9
350 44J config is 11 but has 1 FSM and 2CSS
I’m not sure on the 350 16J config. But basically where it was 10 and 12 in 2019 on the 787/330 and 350 it’s now 9 and 11.
#961152 by ColOrd
22 Mar 2023, 00:47
And minimum crewing is less than that again, I believe a 787 can fly with 7 crew. What your onboard service looks like with that is anybodies guess. I have flown with 8 on a 787 and half of them were off either airport or home standby and it was the single worst flight I’ve ever had with VS!
#961155 by Kraken
22 Mar 2023, 11:25
ColOrd wrote:And minimum crewing is less than that again, I believe a 787 can fly with 7 crew. What your onboard service looks like with that is anybodies guess. I have flown with 8 on a 787 and half of them were off either airport or home standby and it was the single worst flight I’ve ever had with VS!
I thought minimum crewing was 1 crew member per 50 pax - with the condition that each main exit door must have a crew member assigned for takeoff & landing? By main exit door I mean full-size door, not over-wing exits (which are obviously not applicable to VS). This is how the likes of Ryanair get 189 pax on the 738 with 4 crew.
As the 787 has 8 doors, flying with 7 crew would surely mean a certain area of the aircraft would have to be blocked off & be left unoccupied? It was very easy to go "crew-down" on the 747's - just close off the upper deck and you could fly with 2 fewer crew.
#961160 by tontybear
22 Mar 2023, 16:10
Important to note that there is a minimum number of crew required by the regulations for safety and the number the airline needs to deliver its service requirements.
For the A330 it's 8 or 9 for the regulations depending on how many seats there are.
see the tables on pages 31 and 32
https://www.easa.europa.eu/sites/defaul ... 20Crew.pdf
#961164 by declansmith
22 Mar 2023, 20:10
A330 10 crew 5 in economy/ premium 5 in upper
787 same as above
A350 44J 5 in economy, 2 in premium, 6 in upper total - 13
A359 16J - 7 in economy, 2 in premium 3 in upper - Total 12
All aircraft have 1 X FSM
1 X CSS
787/330
4 crew work in economy/ premium with CSS supporting
3 in Upper Class with FSM supporting
The 10th crewmember floats between Upper and Premium and basically clears in the meal service and does tea and coffee to make the service a bit more attentive
A350 has 2 dedicated crew in premium
44J has 13 Crew
16J has 12 Crew
44J - 13 Crew
4 crew in Y with CSS support
2 crew in W
5 crew in J with FSM support
16J - 12 Crew
6 crew in Y with CSS support
2 crew in W
2 crew in J with FSM support
Users browsing this forum: No registered users and 359 guests
