#963811 by dmc
18 Apr 2024, 17:53
I'm flying UC LHR to ATL in a few weeks, I have VS Gold - and I have a same day connection from ATL to AUS on Delta in First, but I had to book it on a separate itinerary as Virgin were unable to add it to my existing booking.
I know normally I would have access to the Sky Club in Atlanta, but I'm assuming the fact it's on a separate booking will make this impossible. Does anyone know if that's the case, or whether I should try it?
#963812 by OliverD241
18 Apr 2024, 18:20
You will not be able to access the lounge I am afraid; as it is not on the same booking. You could see passes for other nearby lounges. It is unfair that on a separate bookings; but I guess it’s to keep the lounges from becoming extremely busy
#963813 by CJ17
18 Apr 2024, 20:04
OliverD241 wrote:You will not be able to access the lounge I am afraid; as it is not on the same booking. You could see passes for other nearby lounges. It is unfair that on a separate bookings; but I guess it’s to keep the lounges from becoming extremely busy
I don't think this is accurate. OP is VS Gold, where SkyTeam Elite Plus rules apply (source: delta.com):
SkyTeam Elite Plus customers (excluding Delta Medallion Members) traveling in any cabin on a SkyTeam international flight* or a SkyTeam domestic flight connecting to/from a same-day international flight (includes same-day travel on a Delta domestic flight connecting to an international Delta –or any other SkyTeam partner—flight) will receive Delta Sky Club access with up to one guest.
And from SkyTeam lounge access policy (source):
SkyTeam Elite Plus members, regardless of their travel class, are allowed access to a SkyTeam lounge at a particular airport if traveling on or connecting to/from a same-day international flight operated by a SkyTeam member airline. Simply present your boarding passes and a valid Elite Plus membership card for the lounge agent to validate for admission.
Just be ready to show your boarding pass from VS and your VS Gold credential.
#963814 by OliverD241
18 Apr 2024, 20:44
I have been denied this in the past when it was not on the same ticket.
In T&CS on delta it does states “ During a layover between Delta-marketed or Delta-operated flights on the same ticket, you may visit the Delta Sky Club in your connecting airport at any time during the layover”.. so pretty sure it needs to be on the same ticket.
Since the INT-DOM is not on same ticket, it’s not connecting flights therefore they may not grant access. I would still try though.
#963815 by dmc
18 Apr 2024, 20:53
Thanks guys - I've seen conflicting answers on different forums - and even the various wording on the Delta website isn't exactly clear, so thought I'd try here, as there's normally at least one person who's actually done it (or not)!
The section about the SkyTeam Elite+ access doesn't specifically say about same itinerary, but also doesn't clearly say the opposite either. The wording about "During a layover between Delta-marketed or Delta-operated flights on the same ticket..." seems to be in the Amex section of the Ts & Cs, so not really applicable directly.
I'm planning to give it a go, will make sure I have printed boarding passes for both and hand them over and plead ignorance.
#963927 by dmc
07 May 2024, 22:35
Just wanted to provide an update now that my trip has started.
Flew Virgin in Upper to ATL yesterday and then connected onto AUS with Delta, on separately booked itineraries.
The Virgin itinerary was a reward seat picked up in the recent sale, and the Delta flight was a cash fare booked directly with Delta.
I turned up at the Sky Club in Concourse F and showed them my Virgin boarding pass I had just flown in on, and my Delta mobile boarding pass for the next flight, and mentioned I was VS Gold. No questions asked, I was let in - just a slight bit of confusion when the agent first scanned my Virgin boarding pass and that didn't provide access (which it wouldn't, because it is a standalone itinerary), then scanned my Delta boarding pass , she tapped a few keys and said "you're all set". :-)
#963934 by mitchja
08 May 2024, 21:40
mvp63 wrote:Does the fact that you had a Delta booking in First Class from ATL to AUS not automatically give you lounge access?
No, domestic US First class (business class) has never included lounge access. Access is based purely on FF status as well as including certain credit/charge card users and not class of travel for pretty much every US airline when it comes to domestic flights.
This is why US carriers are in such a mess with over-crowded lounges.
It’s only on International flights where class of travel starts including lounge access with US carriers.
#963938 by dmc
08 May 2024, 23:27
As another point of interest - I asked at check-in in the Upper Class wing whether they could label my bag all the way through to Austin, adding my separate Delta flight, and that wasn't a problem for them. They didn't even need my PNR, just the flight number. Obviously I still had to collect my bag in Atlanta and go through customs as always, but it meant I was able to just drop my bag onto the connecting flights belt in the transfer area rather than having to go to a desk and get it retagged.
#964042 by dmc
20 May 2024, 16:09
This worked on my return journey as well, FLL > JFK > LHR, I was able to access the Sky Club this morning in Fort Lauderdale after showing I have a same day VS international flight, despite being on a separate ticket.
Also wasn’t a problem for them to add my Heathrow flight to my bag tag at FLL
Users browsing this forum: No registered users and 198 guests
