#965769 by SNOMO
01 Jan 2025, 17:25
Did Upper return Boston in October & decided to boost points flown as thru the new system there are some good points use flights availability for our next trips there . The ability to Boost is no longer available on line & I now need to use the Chat line or call to do so apparently. I cant see the ability to use a Chat Line available when in my FFC account either now?
Try as I might phoning the two numbers available, supposedly to be able to Boost, after 1 hour each time (4 times on each number now) holding, to then be cut off I thought I would ask the question on here,
is there now no way of getting thru to someone on a dedicated Boost line does anyone far more knowledgeable than me knows about please?
#965786 by EstelleB
04 Jan 2025, 19:04
If I've wanted to boost after a flight I've just called up the regular FC number. As you flew UC I think you could legitimately choose the UC option and then you will get to speak to someone who knows what they are doing!
