#966359 by enigma
22 Apr 2025, 22:00
My return UC flights LHR to CUN requires 400000 points, I am silver. 1 have 100000 points plus two vouchers. Can I use two vouchers @ 150000 points each ( total 300000 points) plus the 100000 points I have making a total of 400000, of course the taxes will be in addition , all answers will be greatly appreciated.
#966364 by mitchja
22 Apr 2025, 22:29
No sorry, that not how the vouchers work. The vouchers can only be used as either upgrade or a companion voucher. You can’t use them to pay for the entire reward flight. You can only use 1 voucher per person as well.
If using as an upgrade, you first need to see for much a return Premium reward or revenue flight is going to to cost then the voucher value goes towards the difference between the Premium reward and Upper Class reward or you can use your voucher to upgrade a revenue Premium fare to an Upper Class reward fare.
#966370 by Bluebear
23 Apr 2025, 20:06
Not sure if this helps but how about booking it as 2 x one way flights then you could use a voucher each way at 150,000 points each if you are silver.
You can upgrade from economy to upper or premium to upper depending on how many miles you have.
Users browsing this forum: Google [Bot] and 22 guests
