What are the best Upper seats on the A350 Leisure config ? I have managed to get 1 and 2 A but it looks like they are close to the mini loft area.
Steve
Steve
CommanderB wrote:IMHO the leisure config was not a good choice by VS. But 1/2A should be fine. There is a bulkhead between The Booth and 1A. And people may not even use it. When I last flew that aircraft nobody used it. I’ll be on it again in about 2 weeks.
The big downside of UC on that config is that Premium will disembark before Upper like they did on the old 747s. Other than that, the seats are the same as the normal config.
Joshl257 wrote:It's important to remember the low J A350 was design to replace the LGW/MAN 747's. Now the AC are based at LHR/MAN I think VS should just standardise the A350 fleet to a 44 seat UC cabin. Because VS want to grow premium and upper-class revenues so sticking with the leisure configuration long-term is just leaving money on the table.
OliverD241 wrote:Indeed. Premium off first followed by Upper class and economy. Maybe lucky if the have a 2nd jet bridge (I.e Vegas) but in most cases you’ll follow behind premium. My advice is to do the MPC app or GE if you have it.
Kraken wrote:Whilst I don't have the pleasure of Terminal C for the first time until next week, the only thing that will control your speed through immigration is the baggage reclaim. If they load a container in the wrong sequence in the UK / you land when lightning is in the area (quite possible at this time of year) then you are "messed up" to put it politely. Yes, Global Entry / MPC will help once you have got your bags, but there were reports of 4hr delays last week due to thunderstorms in the vicinity of the airport.
As to the A350 Leisure config, I normally go for row 2 - avoids all the crew rubbish in the overhead bins around row 1 and you are just that bit further away from the Booth / toilet. On my last leisure config return flight, 3 young lads [admittedly in Upper] seemed to think the Booth was a "play den" and even the crew spoke to parents as it was an overnight flight.
