#3122 by a11p0rt
28 Oct 2004, 11:23
We fly out at 1130am on Saturday morning from Heathrow to Miami.
Check in opens at 0830.
Does any one have a strategy for getting the exit seats? There are only 2 of us, both fit and healthy.
Failing that, how do I get myself upgraded??!!
Thanks.
#44537 by Decker
28 Oct 2004, 11:27
Asking for exit seats frequently helps get them if if they are available. You might want to check out the seat maps so you know which ones to ask for. Being an elite member of FC will help even more with this.
For upgrades see http://www.v-flyer.com/upgrades.asp.
#44539 by a11p0rt
28 Oct 2004, 11:36
Decker,
Do you know if I would have to pay for the exit seats? I have seen in other places suggestions of £50.
#44540 by fozzyo
28 Oct 2004, 11:39
Check-in early and ask for them then, I think they can only be allocated then as they have to see you ... would you be able to open the door in an emergency.
Not sure about paying for them.
Foz :o)
#44541 by a11p0rt
28 Oct 2004, 11:41
Early as in 0830 for an 1130 flight or early as in 0730 for an 1130 flight?
Thanks Foz.
#44545 by Boyle73
28 Oct 2004, 12:16
We found the DIY online check in allowed us to change our seats to bulkhead seats, we got upgraded on the flight home (hurricane frances) so couln't check to see if it worked for the return flight.
#44548 by Bazz
28 Oct 2004, 12:37
Hi a11p0rt, you don't say which class you are booked in?
If in coach, you will be asked to pay, £50 or $75 for exit seats. On the 744 for example, you pay extra for seats CD or HJ, the seats nearest the doors A and K are not charged for because of the restricted legroom due to the door bussel which houses the emergency slide.
In PE you don't have to pay extra for the exit seats.
In both cases it helps to get to the check-in early as these seats are popular and usually go quickly even when charged for.
#44554 by fozzyo
28 Oct 2004, 13:04
From the VS Q&A
quote:We must be able to see a passengerÕs physical condition before assigning them an exit row seat.
From my experience you don't have to do 20 press-ups and run around the checkin desks.
Foz :o)
#44555 by Decker
28 Oct 2004, 13:09
I have seen children and injured people moved as unable to lift the door out in an emergency.
#44581 by platinumboy
28 Oct 2004, 19:51
Outbound flights from London subject to £50 fee, check in as usual and ask for an exit seat, they will give you a boarding pass and check your luggage. You will be asked to goto the ticket desk to have your boarding pass updated or changed to an exit seat at which point you will have to pay. 747 have three exit seats, the one closest to the door has a "bump" which is usually FREE, but only offered (usually) to couples. You will be able to buy the aisle seat though.
The new airbus has no bump on the seat closest to the door, and is ppossibly the best seat on the plane, much MUCH more room than PE have! Again there is a charge again of £50. On your return from US its a $75 fee, which works out at about £47 at the moment.
I always get the exit seat if not flying PE or UC, its well worth it! Don't be afraid to ask people to move away from the area if they feel the need to stand in front of you while they stretch and generally get on your nerves!
Enjoy! x
#44592 by fozzyo
28 Oct 2004, 21:36
quote:I have seen children and injured people moved as unable to lift the door out in an emergency.
When we had the Exit seat in PE we were asked "are you fit and able". We both naturally answered yes. But where we fit and able enough? Should airlines actually ask more about your general fitness to get a better idea of whether in the event of an emergency you would be able to open the door. Clearly from Deckers experience the current standard procedure may not be appropriate.
Foz :o)
#44593 by JAT74L
28 Oct 2004, 21:50
Having had the dubious pleasure of opening the overwing exit on a 737-300 recently (it's OK folks it was in BA's maintenance facility in Glasgow!!!) I can confirm that it's a fairly robust piece of aircraft that we're dealing with here. I doubt whether a petite person of the female (or male) variety would remove it with ease. I do think though that events accompanying the need to remove one for real would certainly bring assistance from other pax!
John
#44595 by Nottingham Nick
28 Oct 2004, 21:54
That is a good point, I know on some of the US airlines - including America West - the cabin crew subject people in exit row seats to quite a grilling before take off. They make sure they know how to operate the doors, and are prepared to do so in the event of an emergency.
Without getting ageist about this, I doubt some of the more senior people I have seen sat in exit row seats on VS would be in much of a position to open the heavy doors.
#44602 by declansmith
28 Oct 2004, 22:47
If the load in Y is less than 75% the exit seats are free.
Paying £50 at check in will 'gurantee' you the seat.
You could wait until you get to the gate and if there not taken then you get them for free.
Lots of people to grab the seats at check in, the £50 charge does not seem to put people off.
#44636 by Boyle73
29 Oct 2004, 11:39
We were clearly very lucky to get the option of the bulkhead seats through the DIY Check in. We have asked in the past with VS and got them however had only been asked to pay for bulkhead seats when flying with charters. We flew from Manchester would this be the reason we weren't charged?
#44678 by Nottingham Nick
29 Oct 2004, 16:51
AFAIK VS don't charge for bulk heads - only exit rows. They do try howver to reserve bulk heads for people flying with very small children.
#44761 by Ianflies
31 Oct 2004, 15:14
Twice I have requested bulk head/extra leg room seats in EC. First time the check in crew advised it was too early (?) to allocate these, and when I get to the gate I could request one (needless to say, this did not work).
The second one, upon asking, I was upgraded to PE! As you can imagine, that was the more prefereable option!
#44764 by julesn
31 Oct 2004, 15:34
Bulk head seats are also resevered for passengers with certain medical needs / disabilities.
Although these can be requested in advance, it's made clear that they cannot be guaranteed - but so far I have been fortunate enough to always have my request granted (I hope this doesn't tempt fate!)
jules.
