#4893 by airnewzealand
18 Mar 2005, 23:42
Hi
I will be flying VS in Z class on 17 November BOM LHR. What do you think my chances of scoring a refitted A343 are. I will also be flying NZ LHR LAX then SFO AKL on the refitted 744 and 777.
Can't wait to check out VS for the very first time.
#56165 by Jetstreamer
18 Mar 2005, 23:58
Hopefully by November, 5 out of the 9 A343s will have the Upper Class Suite so you will have a reasonable chance.
Whether you get J2000 or the UCS you'll never forget your first time ;)
#56223 by airnewzealand
20 Mar 2005, 03:36
Do you think they will deploy those 5 aircraft on specific routes or not??
#56227 by VS045
20 Mar 2005, 10:20
airnewzealnd,
I doubt they will deploy aircraft on specific routes, that generally never works with such a large route network.
VS045
#56236 by BlackCat
20 Mar 2005, 13:45
Hmm... some of the A343s are different -- some have the extra grunt to take off at higher altitudes and tend to be used on the JNB route, for example. So I think there could be some likelihood of some routes having more chance of UCS as they are rolled out.
BC
#56295 by FamilyMan
21 Mar 2005, 09:29
Hey ANZ,
I asked this same question here.
There would certainly seem to be a logic in planning them to specific locations as the configurations would be different in all cabins (40/28/187 to 34/36/171) and so selling would be more difficult
As BC states some of the 343s have CFM 56-5C4 engines which are more suitable to the challenging routes (In the past JNB/DEL/CPT but I guess BOM might be included in this list). Of the 5 due for UCS, 3 have these engines and the other 2 have C2's so not the best of correlations.
Phil (Buffy)
#56351 by airnewzealand
21 Mar 2005, 21:41
Buffy
Yes your point makes sense about selling of seats,etc and certain aircraft required for more challenging airfirlds like JNB, CPT, etc though not sure if BOM can be considered challenging.We shall have to wait and see. Also, my BOM LHR sector on my RTW will be my only chance flying VS so praying to get UCS. I rang VS Res and pre booked 3K in UC.
#77087 by airnewzealand
15 Sep 2005, 00:09
All LHR BOM LHR service for October and November will be operated by A346s when it reverts back the A343s when the service goes daily. Wonder why they have changed a/c - anything to do with the refit.?
Rang VS here in SYD who confirmed my BOM LHR in late November will be a A346 - hence: UCS. I am more than happy!
#77117 by Bazz
15 Sep 2005, 10:53
FWIW "BOM" is 3000 26 feet above sea level. Should have read the whole piece instead of just the headline [:I]
#77167 by malikifx
15 Sep 2005, 19:24
Originally posted by Bazz
FWIW "BOM" is 3000 feet above sea level.
Uhhm, BOM is pretty much on sea level, I think.
And you should be lucky you don't get the green-engine rattle-trap on LHR-BOM that we seem to get on LHR-DEL.
#77175 by ColourPhil
15 Sep 2005, 20:13
Can't be more than a few feet above sea-level. Airport not too far from the sea either. All pretty flat around there as well.
