#7246 by MixedUpRichard
06 Aug 2005, 15:30
Hello
I've been talking to some friends who have flown with other airlines and they've said that sometimes there are cameras on the front of the planes or underneath the planes so you can see the takeoff from below or the front of the plane on your seatback tv.
Do Virgin have these? If so, are they only on certain systems? V-Port? Or all of them?
Richard
#72416 by seany
06 Aug 2005, 16:15
There's this, I never used it myself but I think it's on all V-port aircraft.
#72420 by preiffer
06 Aug 2005, 16:24
Sean, I think that's a camera for crew access only. [?]
As far as I'm aware, VS do not have cameras available for passengers to use. BMI, and other carriers operating A330's do though...
#72421 by mitchja
06 Aug 2005, 16:25
The external cams on the A346 A/C are only available to the flight deck crew.
Sorry but no VS A/C have any form of external cameras available to PAX through the IFE.
Although VS should serioulsy consider it as it's been mentioned numerious times on here.
#72423 by seany
06 Aug 2005, 16:29
Ah I see, thanks for clearing that up[y].
#72443 by p17blo
06 Aug 2005, 20:14
If you like the thought of seeing where you are going whilst travelling you should try a cruise with Royal Caribbean as all of their ships have a 'Front of the Boat' channel.[8D]
#72468 by Tinkerbelle
06 Aug 2005, 23:17
Yep these cameras are used by the pilots when taxiing. They are not normally used once in the air
#72479 by lynnewob
07 Aug 2005, 07:09
Emirates have them.
I usually set mine to front of plane on take off while hubby sets his to underneath the plane, so we get best of both worlds on take off and landing. I'm not sure of any other airline who has this option though.
#72503 by Richard28
07 Aug 2005, 16:05
I understand that Airbus offer the option to have the video feed linked to the IFE - for some reason VS did not take this option.
SAS have the video on their A321's - the front camera is located on the front wheel gear, and when this retracts after takeoff you have down view only.
the tail mounted camera looks fab on the 346 - shame we cant see it!
#72583 by Jonathan
08 Aug 2005, 11:50
VS should pick up on this as:
a) they're not expensive
b) a lot of other airlines have them ..inc some charters!
#72633 by Nottingham Nick
08 Aug 2005, 19:07
I agree, Gulf Air have the cameras and, they are great.
The problem with VS fitting them is that it takes so long for them to get the IFE fired up after take off, and the fact that they shut it down so long before landing would mean that we would miss the most interesting shots[:(]
#72641 by VS-EWR
08 Aug 2005, 19:41
Of course, if VS were to just route the pictures to the IFE screens during take of and landing, it wouldn't really be a problem. I remember seeing a picture on A.net of a SAA flight during taxiing where they had the forward camera view on the screen.
#72652 by Richard28
08 Aug 2005, 20:20
absolutely - it is not impossible to do.
If you examine V:Port before it is "switched on" there are two "blank" channels - which show the lava lamps/safety video. It would be easy to switch this to the live video feed (if it were connected), after all safety stuff is broadcast.
Full V:Port activation would not be necessary to achieve this.
VS-EWR, the SAA A346 picture is here!
Rich.
#72670 by FamilyMan
08 Aug 2005, 21:53
I guess the next question is..
If the feed was connected in this way would individuals be able to turn off their screens or would they be stuck with it the same way they are stuck with the lava lamp and safety video's.
I can think of a few people who would not really want to be watching it. :)
Phil (Buffy)
#72671 by preiffer
08 Aug 2005, 21:57
BMI have this issue Phil - I was on a flight last year, and we asked to have the front-camera left on for landing in the front of the plane. Apparently (although not sure how true it really was), that meant all of Y was forced to watch the landing, too.
#72683 by VS-EWR
08 Aug 2005, 22:53
Well, you know what I say? Tough Luck! :D
EDIT: But wait, if the SAA 346 tail cam is on a channel like the caption says (by the way, thanks for finding it Richard!), and the screen next to the photographer is black, then there must be a way to have it be optional. Or maybe that's just for taxiing?
