#73062 by HighFlyer
12 Aug 2005, 09:35
Hiya
Yes, if you are travelling UC and have a guest also travelling VS on the same day you can bring them into the CH as a guest.
If you mention this at check-in they usually write '+1' on your invite, but failing that it shouldnt be a problem if you just turn up at the CH with your guest as they *should* all know the rules and sign your guest in under your details.
Be prepared that your guest may get hooked and want to travel with you all the time ;)
#73079 by Jonathan
12 Aug 2005, 11:38
just to add a few extra points:
Your guest doesnt have to be traveling with you (or even on the same flight!)
the only condition is that they must be on a vs flight that day (and given the CH at LGW is airside that means checked in too)
