#7644 by preiffer
29 Aug 2005, 08:39
Just looking at a booking for January to New York, and VA.com gave me the following options:
20 JAN 09:30 New York (JFK)
20 JAN 12:10 VS045 7:40 Hrs B744
20 JAN 14:00 New York (JFK)
20 JAN 16:40 VS003 7:40 Hrs B744
20 JAN 16:00 New York (EWR)
20 JAN 18:40 VS001 7:40 Hrs B744
20 JAN 17:55 New York (JFK)
20 JAN 20:50 VS009 7:55 Hrs A343
20 JAN 20:30 New York (EWR)
20 JAN 23:10 VS017 7:40 Hrs A343
Now, I've added the aircraft type myself, from ExpertFlyer.com - as I couldn't work out what was going on.
I know the A343 is the slowest plane VS have, so assumed that might be the cause of the extended flight time - but alas, no. The EWR flight (744 vs 343) contradicts that theory, as both aircraft offer the same flight time.
I thought, MAYBE they're factoring in holding/traffic at that particular time of day - maybe they intentionally slow down to hit a slot at the other side of the water in that case?
So... Does anyone know the "real" reason why VS9 takes an extra 15 minutes over all other NYC flights?
#75070 by Bazz
29 Aug 2005, 10:59
I would guess its to do with landing slot/gate availability or mcuth might be onboard [:p][}:)];)
#75074 by mcuth
29 Aug 2005, 11:54
More like an hour extra in that case ;):D
Michael
#75077 by seany
29 Aug 2005, 12:02
A more direct flight path perhaps?
#75084 by VS-EWR
29 Aug 2005, 14:26
Well, no EWR flights are operated with a 343 anymore, whether they will be in the future I'm not sure. But maybe they mistakenly put 343 for 017 when it really shouldn't be that.
#75124 by NYCFlyer
29 Aug 2005, 21:23
Wasn't the VS9 previously 1805 ex-LHR? If they have put it back to 1755 they are most likely not to be able to move their Slot/Gate time in EWR as they are very restrictive there. Would certainly seem to be the most likely scenario.
Graham
#75130 by VS-EWR
29 Aug 2005, 22:12
Graham
VS9 goes to JFK not EWR by the way, but yes, that could very well be, they may know that it will take longer to get a slot and anticipating that, they changed the ETA.
#75135 by Richard28
29 Aug 2005, 23:27
this is not specific to VS.
BA for example have flights varying in time on the LHR-JFK route from 6hr 20 mins to 7hr 45 mins - with both extremes serviced by the same plane type (B744).
I think the scheduling is more to do with slot availability at departure and arrival airports - certianly these timetables will make an allowance for the normal expected jetstreams, but individual routings are not decided until day of departure.
#75153 by NYCFlyer
30 Aug 2005, 08:04
Originally posted by VS-EWR
[i]
Whoops, a bit of slip up there, I should remember as I have been on it enough times. I really should be more awake for posting!! [|)][|)]
#75181 by VS-EWR
30 Aug 2005, 15:41
Hehehe, no problem. Although sometimes when airlines make that mistake or just say NYC instead of EWR, it makes me so angry [:(!][B)]:D.
