#8175 by xenole
01 Oct 2005, 02:13
There are two connectors on the inside of the right hand arm rest near the button for reclining seats (well in economy at least). The bottom one is for a normal 3.5mm headphone jack, but what about the smaller top one?
#79197 by preiffer
01 Oct 2005, 02:17
It's for the power to Noise cancelling headphones.
If you plug your own regular headphones in, they won't use it.
If you plug your own NC headphones in, they'll have their own power supply (battery), so again - won't use it.
If you use VS' own Upper Class headphones, they come with two male connectors - one for the audio, the other to power the noise cancelling element of the headphones.
The NC properties of the VS supplied ones aren't great, but certainly better than nothing. The design is used by several airlines - you can use BD/AC Business Class (Noise Cancelling) headphones in the VS socket configuration without any problems.
