#8260 by locutus
06 Oct 2005, 00:33
I've just signed in to check my booking on the VS web site, and my outbound flight isn't there, just the inbound one.
Is this likely to be a glitch or a warning that something bad is about to happen to me? [:(!]
I only wanted to make sure they were still planning on having a 747 for VS046. hmmm.
#79869 by Richard28
06 Oct 2005, 01:14
The exact same thing has happened to me today (was going to play musical chairs per the other thread!)
hopefully just a short term bug - I'm going to try again tomorrow....
#79881 by Vegascrazy
06 Oct 2005, 08:02
Same thing happened to me a few weeks before our trip in September, i.e. the return flight disappeared. I called VS who said nothing to worry about, there had been a 5 minute change to the scheduled departure time of the return flight and that causes it to temporarily not show on-line. Sure enough it returned soon afterwards showing the revised departure time.
#79883 by ela123
06 Oct 2005, 08:35
This happened to me as well. It was just a small change in the departure time like Vegascrazy. It comes back when you're notified so a quick call to VS should do the trick.
#79895 by stevendq
06 Oct 2005, 10:33
Happened to me too. As already mentioned, I was told it was because of a scheduled change and once the customer has been notified it re-appears.
#79900 by locutus
06 Oct 2005, 11:04
It seems my flight is going to take 10 mins longer than scheduled, so that's why. Apparently it'll reappear soon.
Thanks for the comments. :D
#79928 by Richard28
06 Oct 2005, 14:15
just checked mine again, and still only the outbound shows.
The VS201 SYD-LHR is still missing [:0]
#79940 by locutus
06 Oct 2005, 15:23
Originally posted by stevendq
VS001 by any chance?
Yes indeed, what's happened to it then?
#79943 by stevendq
06 Oct 2005, 15:33
Not sure, only 10mins longer to get there so its not a big deal. Probably something to do with slots at EWR.
I'm on the same flight (18th Nov) so I also had the problem.
#80011 by VS-EWR
06 Oct 2005, 22:47
I think it's to do with traffic, not slots. The concourse in terminal B that VS flies into isn't that busy, but as there are more and more flights coming and going from EWR and only 3 runways (1 of which can only be used by smaller aircraft) it spells delays.
