#28930 by freeway
12 Apr 2004, 18:25
There is a lounge for UC pax to use, it is a shared one though
I think Delta lounge........
#28940 by The_Banking_Scot
12 Apr 2004, 19:42
Freeway is correct. Virgin Share the Delta Crown Room lounge ( beside gate 70 I think airside- In the terminal that VS uses so it is reasonably close ot the 80's gates that VS uses.
TBS
#28949 by RichardMannion
12 Apr 2004, 21:22
The shared lounge is the Delta one as pointed out earlier, it is on the second level of the atrium of the departure annex. Where the atrium is next to the transit trains, the one with Starbucks to the left, the lounge goes all the way around overlookign the main level below :)
You can also get in their with a Priority Pass if you're not flying UC or VS Fc Au.
Richard
