Just a quick question... as a general rule, if passengers have not pre-booked their seats, do check-in staff generally fill the seats from front to back in that order??
Originally posted by Virgin Lover
Generaly seats are allocated at check-in, if you have not prebooked or used DIY or On Line. The Computer allocated the most suitable seats for your party, and it is usually done in a distributed manner. eg, if the flight is only a quarter full they don't sit every one together! This helps keep the loading even.
You can however ask to sit anywhere you like and they will try to accomodate you if the seats are available. They will not have allocated seats for people who have not checked in yet, unless they are pre-booked or checked in on-line.
If you want to sit in a specific area of the aircraft then either check-in online (the best way) or arrive at checkin prior to it opeining and then you will usually get what you want.
Please remember that there are no guarantees and even if you pre-book or checkin online, they can still change you seats right up to boarding.
Hope this helps.
Neil.
PS: Posting in Capitals implies that you are shouting!
Originally posted by catsilverswordThey could well have got 70 A,C, H & K.
I asked if I could change my seats - expecting them to say no as it was a full flight - to be told that the party of 4 in front of us had just taken the last 4 seats in PE! Not happy about this - how can it be that I kept cheking and checking and was unable to change and yet 4 people walk up at check in and get seats where they choose? I've written to VS customer services (natch, but their reply, although courteous, gave me no real answers..... anyone had this happen? Am sure someone must have done!
Originally posted by preifferOriginally posted by catsilverswordThey could well have got 70 A,C, H & K.
These are exit seats, and therefore only assigned at check-in (you won't have been able to pre-select them). It's perfectly normal for this to happen, and not really a customer service issue if it is the case.
Originally posted by jillyOriginally posted by preifferOriginally posted by catsilverswordThey could well have got 70 A,C, H & K.
I'm sure Paul is correct. On our full PE flight to LAS earlier this year we asked at twilight check in to be moved upstairs and were given 70A and C.
Jilly
