#9182 by robandgill
30 Nov 2005, 00:39
Hi all
I've been reviewing some flight availability data and seating plans from expert flyer for a forthcoming one way EWR-LHR night flight next week. Presently I'm booked in PE (S) and would very much like to try out UCS for the 1st time.
Does the information presented in the seat plan accurately reflect the number of upper class seats left or should i rely solely on the availability data returned which is at present is showing
J7 D7 Z3
I've phoned flying club several times to try for a confirmed upgrade but it looks like it will be a wait and see on the day job.
Many thanks for any expert advice
Robert
btw anyone know why Z is available this close to the flight ?
#86127 by Pete
30 Nov 2005, 04:31
That will mean there are 7 or more seats available in Upper Class, or which there are 7 (or more) in J, 7 (or more) in D and only 3 in Z.
There are two things to remember when reading availability numbers, (a) they cap at either 7 or 9 (or sometimes even 4) depending on the system, and (b) each cheaper bucket is a sub-set of the next more expensive, and the numbers shouldn't be added together. This means if you see (for instance) J5 D4 Z3, there are 5 seats available; all of which are available at the full fare; 4 at the D fare or 3 at the Z fare. If you want to be fully flexible, you can buy them all at J, but if you want the deeply discounted tickets, there are only 3 of them.
Pete
#86139 by mike-smashing
30 Nov 2005, 08:53
Additional award inventory is usually released between 5 and 7 days, and then again at 24-48 hours before the flight. It may be worth phoning back closer to the time.
Some Z fares for ticketing from Mainland Europe origins don't have as rigid advance purchase requirements (can be bought about a week before the departure date).
#86303 by robandgill
01 Dec 2005, 00:22
Guys
Thanks for the advice. I'd pretty much grasped how to translate the availability code. I'd been keeping a close eye too on the seat map on expert flyer, which seeming is filling up at alarming rate and I was kinda assuming that meant the flight was quite quickly becoming full in J therefore reducing chances of upgrade success
Robert
