#9799 by locutus
09 Jan 2006, 10:17
Sorry for another annoying seat question. I've reserved seat 74C for both my flights, I'm happy with the choice outbound, as I can get up easily, don't annoy anyone behind me and I was first off the plane last time so got out of Newark very quickly.
Anywho, on the way back, I'm pondering 74A (unless I can get row 70) as it may allow me to sleep a bit more, but my question is, with the shape of the airframe and the locker, is it possible to lean against the window side as I try and sleep, or should I stick with 74C?
Hope that makes sense!
TIA.
#90980 by preiffer
09 Jan 2006, 17:27
From memory, I think there's about a 6-9" gap between the seat and the wall on the upstairs PE seats.
The pillow should bridge that though...
#91089 by VS045
09 Jan 2006, 22:38
I think you should be able to lean on the window maybe. If you lie at angle to the seat, then you probably can, although your legs may "invade" your seat-mate's space, so it depends how friendly you are with them!;)
Also, you may need to visit a chiropractor after achieveing this feat. However, I think it would be far more comfortable to stay in the seat you're in and just lie back in the chair.
VS045
#91093 by HighFlyer
09 Jan 2006, 22:44
I have slept (well, been in an alcohol induced coma) with my head against the window in PE. Had a real bad neck ache when i woke up but it can be done! The best thing to do is steal your mates pillow and use that with your own to plug the gap! Nice and comfy!!
#91110 by MarkJ
09 Jan 2006, 23:26
Yes there is a gap - I still think that 74C is the better choice as its easier to get out of to go to the loo and you have the handy side table for drinks etc - however - if you get to check in early enough its always a good idea to go for the exit seats because then you have lots of stretch room and the exit door to lean on.
I think Sarah has a picture of her in that exact seat ( along with her handbag!!!)
