#9976 by andypov
15 Jan 2006, 23:10
Can anyone tell me whether it is possible to combine miles from accounts to make a booking. I have 73760 miles (not quite enough for a pair of returns to MCO) while my wife has 33334 miles (not quite enough for 1 x return trip to MCO). If we are allowed to pool them, we've got more than enough between us to do it. And obviously as the situation worsens a little if we book after 01.03.06, if we can I'd like to organise it sooner rather than later.[:?]
#92439 by HighFlyer
15 Jan 2006, 23:25
Hi there
Yes you can split miles between accounts, usually 50/50 or 75/25, not a problem. The only rule is that (as far as I know) the miles for each sector have to come from one account Ð so you can buy three sectors (your return and her outbound, while she buys her inbound) ThatÕs the only restriction I know of
When you call Flying Club if you explain this is what you want to do, they should easily be able to process your booking.
You right on wanting to get there before 1st March though - id call them in the morning ... you know you want to :)
#92440 by andypov
15 Jan 2006, 23:36
Thanks for the prompt reply, I was hoping that might be the case. I'd better get my skates on and get on the phone to confirm and book.
Cheers.:D
#92442 by HighFlyer
15 Jan 2006, 23:47
No worries
Let us know if you snag those seats to MCO!
#92443 by mcmbenjamin
15 Jan 2006, 23:47
Are 19k/1k splits for U/Gs possible :)? {/smart ar@e off}
#92445 by HighFlyer
15 Jan 2006, 23:56
Ben are you serious??
For what exactly? 1k miles is easy to either earn or get around if you are serious ... you after an upgrade perchance?
#92446 by preiffer
15 Jan 2006, 23:56
Yes, if the reward is made up of 20 individual sectors of 1k ;)[:p]
#92472 by p17blo
16 Jan 2006, 00:58
I believe the OP will still have a problem. VS have never let me do anything other than use my miles for 1 complete sector (which I think has been said already, but the technicalities went a little over my head). This means at present 80k miles are needed for a return G to MCO. This also means that the OP will need at least 40k for each segment. Whilst the OP has enough to cover this, his wife does not.
I would like to hear how this goes.
#92473 by HighFlyer
16 Jan 2006, 01:06
OP didnt specify whether they wanted a G or a U or a T .. i guessed the mileage that it was a T they were after?
#92483 by p17blo
16 Jan 2006, 09:56
A ha, you are correct. Note to self: Get out of UC mode.
See what flying UC does to you.....
#98664 by GatorBaiter
11 Feb 2006, 09:30
Kind of one the same topic as original post, hubby and I both have the 50K miles needed for a free return PE flight LHR-JFK. What I wonder is whether I can call up FC and make the booking together using miles from two accounts so that our seats can be booked together and it's all in one tidy booking?
Jacq
#98668 by Littlejohn
11 Feb 2006, 09:51
Yep, they should have no problem with that. The rear admiral and I did it down to CPT just the same - we have separate tickets, but were together and our bookings were linked just fine.
#98669 by p17blo
11 Feb 2006, 09:54
Jacqueline, Yes (well sort off). FC Call centre can do this and get (or request) you seats together. You will have two booking refs though if you have two different type of booking (ie 1 free mileage and 1 rev). But I do this all the time and the only time I have a problem is when they change the aircraft as the computer shifts you around and doesn't sit you together again, so my adivse would be to keep and eye out for aircraft changes.
#98673 by GatorBaiter
11 Feb 2006, 10:15
Thanks, guys! As ever, you've been extremely helpful and knowledgeable [oo]
I'll get on to FC today and see what I can sort - I'll keep you posted.
Jacq x
PS gotta make the most of mileage bookings before the end of the month!
Users browsing this forum: Google [Bot] and 152 guests
