#10040 by Kryten
17 Jan 2006, 17:46
http://www.chron.com/disp/story.mpl/met ... 90623.html
A continental engineer got too close to a 737 engine in Houston during checks and was sucked into it [:0] This happened whilst people were boarding the plane! The coover of the engine was open following an earlier problem but bot heard much else.
That is not a nice way to go [:(]
#92851 by Littlejohn
17 Jan 2006, 18:50
At least it's quick, although it can do quite a lot of damage to the fan blades which is a downside
#92853 by patrickj77
17 Jan 2006, 18:53
A quick way to go but still.... That is scary!!
#92856 by Kryten
17 Jan 2006, 19:00
Downside? I would have thought that the deaath would be the downside rather than the damage to the aircraft ;)
It is a quick way to go though, I imagine that there are a lot worse ways to be killed/injured by being a mechanic on an aircraft!
#92858 by slinky09
17 Jan 2006, 19:03
Nice to see you've got your priorities right Sailor [:I][:I]
How gruesome!!!
#92865 by Littlejohn
17 Jan 2006, 19:27
Could have been worse - the flight could have been delayed
[:#][B)]
#92868 by slinky09
17 Jan 2006, 19:33
LMFAO
You deserve that purple eye [:0]
#92869 by Scrooge
17 Jan 2006, 19:34
[:#][B)]
dude...that is way to cold,even for me ! [n][V][:#]
#92875 by some guy
17 Jan 2006, 19:51
Can understand why the engine was on during boarding? Even if it was 'windmilling', surely it owuldnt produce enough suction?
#92878 by tallprawn
17 Jan 2006, 20:01
I was just thinking that, An engine running at a minimal rate would blow an open cover straight off???
Cockpit error must have occured??? Or engine mapping malfunction???
#92888 by jamie
17 Jan 2006, 21:30
I don't understand, if the engine was just ticking over i wouldn't have thought it was powerful enough?
#92895 by Richard28
17 Jan 2006, 21:37
I was only looking at the engine cover of a 737 yesterday, and it says on the side that you must give 4 meter clearance to the side and in front of the engine to avoid a problem.
The incident was at El Paso (not Houston), I can only think that the engines were left on idle to facilitate a quick turnaround? Although this is unlikely, as if the pax were boarding from the tarmac, then they too would have been at risk.
Under normal circumstances engines are spooled up during pushback, where there is normally a member of staff who walks out with the plane and is connected to the airplne with a headset, to communicate with the pilots. Perhaps it was a journalistic error, and it was in fact this guy who strayed to far?...
#92979 by Scrooge
17 Jan 2006, 23:48
While showering I started to do the math on what it would take to suck a man into an engine..well it dawned on me that this engine would of have to of been running at something around 65% to get enough force up to move the ave male adult..the story linked above doesn't go into it,but after searching around I found that the engine was run up due to a previous problem with the engine...ok now the problem I have with this is,why were CO boarding pax using stairs not a jetway when an engine is being run up?
#93246 by Lipstick
19 Jan 2006, 10:35
As an engineer, shouldn't he have known better?
We're shown a film of this happening in training. But the bloke survived!
#93260 by mike-smashing
19 Jan 2006, 11:26
Right, I read the thread about this on a.net... last time I looked, it was quite reverent and hadn't degenerated into A vs. B or anything like that.
As Lipstick says, the threat of ingestion into a running engine is made very clear during training.
The 737 is especially dangerous because it's engines are mounted so close to the ground, and on the shorter models, the -600 and -500, also very close to the nose gear.
Apparently, whether you can survive an ingestion or not depends on the engine type. Some engines, like the old Pratt JT8Ds on the 737-200, have a grid of guide vanes in front of the fan, which can stop something as big as a person being ingested.
Newer engines, like the CFMs on the later 737s, don't have the "grid" of fixed metalwork, so being sucked directly onto the spinning fan and through the engine is a real danger, as we saw demonstrated this week. Poor chap, at least it was quick.
It was also interesting to note differences in procedure between airlines and between the UK and US with respect to things like airstarts (being started using a compressed airhose, usually because your APU is inop). It seems that the UK airlines may have slightly safer procedures in place to protect their staff around running engines.
Finally, a pic which sums it up. While this is from a primarily GA airfield, so it's mostly prop aircraft, though there's about 4-5 737 movements a day now as well, this sign (clicky) puts the dangers of an active apron forward in an unambiguous way.
(This sign is on the walkway between the grass parking for visiting light aircraft and the apron exit at Blackpool.)
P.S. There was some conjecture whether the EMB 170/190 will pose the same ingestion threat as the 737, as it is similarly low to the ground and has low-slung engines.
#99463 by PVGSLF
14 Feb 2006, 23:32
There was an email doing the rounds a good few years ago with someone getting sucked into a US Navy Jet on a carrier. Genuine or not I don't know, but it wasn't a pretty sight coming out of the exhaust.[:$]
