Hello ov08
The answer to this is yes. I believe it is only the cardholder and the cardholder must be flying VS that day. It may allow a guest access, I can't remember if the guest has to be a supp card holder or not.
If you do a search in the forums for 'Amex' and 'Clubhouse', this topic has come up many, many times in the past. I ams ure you will find everything you need to know.
Yup, Centurion gets you into VS Clubhouses, although it's the cardholder only; no guests. Of course, if you have a supplementary cardholder that has the Centurion card too (as opposed to the Platinums and Golds you can attach to your account), they are also a Centurion cardholder so have access too.
Pix
Pix
Centurion gets you into all VA Clubhouses, as has been said, it is the primary (black) cardholder and the supplementary (black) cardholder only and you must be flying on a VS ticket on the day of travel, although I have been allowed in when on a CO codeshare on VS metal. As with FC Gold, you class of travel is of no consequence to your admission.
Just to add - it is the Virgin Clubhouses only. It is not for the shared lounges - that siad most of the shared lounges are covered via the Priority Pass scheme anyway.
VS Gold's can use the clubhouses and the shared lounges.
Richard
Richard
