#19843 by phantomtwin
25 Jun 2007, 18:25
Hi -
I'm in Las Vegas for a few days before flying UC out of Lax ON 17th on VS024 which departs 20.50.
Not as yet booked the flight out of LAS - LAX.
Any advice on airlines for the LAS - LAX leg - and also if it will be possible to check my bags thru to London. As we're UC on Virgin we're likley to have a bit of luggage!
Also - in terms of lounge accesss at LAX - I gather it's the NZ lounge as there is no clubhouse.
Is it any good?
Just want to make the best use of my time in Vegas for a relaxed departure and to not spend hours and hours in LAX without the pleasures of a clubhouse.
Any advice or suggestions welcomed
thanks
Andrew
#175659 by honey lamb
25 Jun 2007, 18:40
Originally posted by phantomtwin
Hi -
Andrew
Hi Andrew
As your LAS-LAX flight is not on the same ticket as your VS flight, I'm afraid you will have to collect your bags and re-check in at LAX. You will not be able to check them through to London. It's explained here Sometimes you may be lucky and get someone who will do this for you at check-in but generally speaking "the computer says no"
#175662 by Scrooge
25 Jun 2007, 19:55
I had US say yes in Dec, they are in the same terminal as VS as well.
#175678 by mas66
25 Jun 2007, 23:32
Hi -
Is it any good?
I have used the Air NZ lounge a few times and have found it to be just fine, clearly not the same as a Clubhouse but nevertheless one of the better lounges in the US (IMHO). Its far better than the old Air Canada lounge used to be !
Cheers and have a great trip
Mark :D
#175688 by spurs_fan2201
26 Jun 2007, 10:50
We also had US say yes in April, in fact they offered after asking if LAX was our final destination and we explained that we were connecting to VS8, we were also on seperate tickets for the two legs.
#175759 by phantomtwin
26 Jun 2007, 21:15
thanks guys - as ever helpful stuff - I'll try the US option and look forward to a few glasses of Sauvignon Blanc in the NZ lounge!!
regards
andrew
#175762 by Scrooge
26 Jun 2007, 22:03
I did however forget to say that we still had to go to the VS desk to get the clubhouse pass.
