Originally posted by ade99
The best example I've seen of this was from Honolulu to Kona (less than a 25 minute flight) The amount of carry-on everyone was trying to stuff into the lockers was unbelievable and hilarious as when you got there you simply get off the plane and walk to the terminal which is under a thatch roof and all the ground crew do is take it out the hold and put in on the conveyor!!
Hawaii is a special case re Americans, luggage, and carry-on items. Unless you've lived in the islands, you probably wouldn't know that the kamaiinas treat the inter-island flights like mainlanders do buses, with their assorted shopping going along.
Due to some of the produce requirements (ex-Hawaii flights), if a bag is mis-loaded or offloaded incorrectly, the contents of the day's shopping could go in the bin. The cost of food is high enough in Hawaii without having one's groceries go into the trash for a baggage error!
Certain inter-island flights are operated by a carrier well-known for inability to read tags, routing labels, or warning labels and should be really called 'Checking bags? Lost bags 'r' us'... No local checks a bag on those flights. Trust me.
If you remembered seeing home improvement items carried on, that's because there's much more choice in Honolulu than anywhere else, and some items have a waiting list. If someone's just waited six weeks for a special order to arrive, I can guarantee they're going to keep both eyes on it. If produce or meats, the same.
If you were on one of the early-morning flights, I can also guarantee you weren't seeing tourists. Travel agents don't book them on the before-0630 flights. I used to tell tourists to avoid those early flights due to the overheads being full to the brim, as well as the cargo bins. The larger tourist bags might not fit on the flight if checked in late. Local baggage will always be loaded on early flights before tourist baggage - even if they deny that, I've seen it happen.
The planes are so heavy it's miraculous they rotate, but I can assure you they also land like lead sleds and need full rollouts, not for the faint-hearted or nervous-Nellie flyers...[:0]
