#709223 by locutus
04 Mar 2009, 18:24
I've never been asked to prove my laptop works, but I'd carry the charger just so you can show it passes POST just in case they want to check.
#709224 by Guest
04 Mar 2009, 18:28
I have had to boot up my laptop a few times in the USA by TSA officials so not sure if you will have a problem or not.
Sorry :-(
Regards,
Hackneyguy
#709226 by mitchja
04 Mar 2009, 18:51
I've also had to boot up my lap-top a few times when going through US security too.
#709227 by GodAtum
04 Mar 2009, 19:02
Oh ok, my laptop has to use mains power to work, will they allow me to plug it in?
#709231 by Guest
04 Mar 2009, 19:10
You can always ask but to be honest I doubt it.
#709238 by Tinkerbelle
04 Mar 2009, 20:10
They've never asked me to switch my laptop on but I've had to switch my Ipod on loads of times for them and even take the battery out of my mobile to show them.
#709278 by pjh
05 Mar 2009, 00:37
ISTBC but I thought it was the battery that was the suspect device, not the pc/ ipod / phone i.e. the switching on is not to show that the device works but rather that the battery is actually a battery ?
#709298 by northernhenry
05 Mar 2009, 10:17
You're going to need a battery no doubt. Is it worth just getting one, so the issue goes away? As you'll be stuffed if you need to prove it and can't and can't see security being too forgiving...
#709300 by slinky09
05 Mar 2009, 10:25
I am surprised at how many people have been asked to switch on their laptops etc. I'll guess that I went through security 40-50 times in US airports last year and was not asked a single time ...
#709301 by Darren Wheeler
05 Mar 2009, 10:38
Look around for a cheap, generic battery. Murphy's Law says if you haven't got a working battery, you will be asked to switch it on.
Better to spend a few quid on a battery now than either be refused access air-side or have to abandon your laptop.
#709309 by HighFlyer
05 Mar 2009, 12:06
I've been asked to switch on my laptop before in the UK and US, one time my battery was dead and I told them this and they were fine about it. Another time I was asked to remove the battery and I said that my work was in standby so I couldnt without shutting everything down first and again they said it was fine and not to bother. I do wonder if part of this is just a routine of sorts.
Personally, I'd take the risk, I dont recall needing a battery as a condition of travel, but it depends how comfortable you are with that.
#709354 by GodAtum
05 Mar 2009, 18:58
I suppose I could take the battery with me and say the battery is not charged so I need to pug it into the mains?
