#258576 by pjh
27 Mar 2009, 14:50
Excitement is mounting chez PJH as it's now only a fortnight to our trip to Chicago. Sights to see are being prioritised and the offspring are getting nervous about their parents' inability to decide on places to eat. The only thing I haven't managed to arrange is a trip to the ball game on the Monday, as it's SRO.
Anyhow, we are staying at the Conrad Hilton on North Rush Street. What's the best way to get into that area ? Should I be simply opting for a taxi or are there other options ?
Thanks in advance for the guidance.
#711122 by mitchja
27 Mar 2009, 15:00
If you dont mind using public transport, by far the cheapest (and often quickest) option is to use the Blue Line.
I think it's something like $2.25 each way and takes about 35mins to get into the city area.
#711123 by pjh
27 Mar 2009, 15:02
quote:Originally posted by mitchja
If you dont mind using public trasnport, by far the cheapest (and often quickest) option is to use the Blue Line.
Thanks James. I'm of a mind to use this. This may sound like a daft question, but is it suitable for people with luggage ?
#711125 by mitchja
27 Mar 2009, 15:08
It's not too bad. Most of the stations have disabled access wide entry/exit gates you can use with luggage and most (if not all stations) are manned so there's always someone their on hand to help if required.
Lots of the inner city stations are only accessable via steps though as they all tend to be either under-ground or over-head.
#711129 by slinky09
27 Mar 2009, 15:44
There's a good page on the Chicago transit system Web site here. I've always cabbed it or been picked up so can't comment on other modes but if you want rock bottom price then the Blue line and some luggage carrying, or a cab will be $40-$50 which sounds more reasonable if there are x2 or more of you?
#711137 by pjh
27 Mar 2009, 16:24
Yep, there are 4 of us...
#711148 by tontybear
27 Mar 2009, 18:28
I used the airport shuttle bus last November with no problems at all.
I cant remeber whihc oine it was - I found it on the ORD website. There were also a couple of discount codes available too that reduced the fare by a couple of $$
But if there are more than 3 of you a cab might just work out cheaper.
