#731012 by pjh
30 Nov 2009, 13:48
In principle it's quite clever, they'll get themselves noticed but I'm not sure that setting it in a city that looks a lot like NYC is going to win them any admirers.
#731013 by honey lamb
30 Nov 2009, 14:28
How many polar bears were harmed during the making of that ad?
#731014 by Pete
30 Nov 2009, 15:37
Irresponsible advertising, if you ask me. Apart from the view that Plane Stupid are putting way too much focus on aviation (I understand subsonic aviation in total accounts for 2-3 percent of global emissions), they imply every passenger on that jet is killing a polar bear - and that simply isn't the case. Their over-simplified message that an adult polar bear weighs the same as the amount of CO2 generated by a passenger is an unrelated number, but designed to make those without the attention span to realise it's a flawed message to light their torches and arm the pitch forks - because us air passengers are killing the cute polar bears. Grrrr...
#731015 by fozzyo
30 Nov 2009, 15:54
The effects are good ... but the message just doesn't make sense to me. Mind you, neither does the Plane Stupid campaign.
Mat
#731029 by Bill S
30 Nov 2009, 20:59
Can you imagine the reaction to this in NY?
The parallels with 9/11 are clear.
Plane Stupid have just declared themselves as terrorist sympathisers. (might not be too far from the truth!)
#731040 by centurionman
30 Nov 2009, 23:48
That advert is terrible. Direct action groups such as that annoy me by using emotionally charged imagery to attempt to overcome the premises in debate, reasoned analysis and solution.
#731042 by Decker
01 Dec 2009, 06:33
Bill
S**t ad but don't see your point? Polar bears falling from the skies is not the same as planes flying into buildings? To me it was wooly, poorly conceived and a waste of time. And I still don't understand why polar bear skin rugs are so expensive.
#731048 by pjh
01 Dec 2009, 09:06
Bill
But it is very, very close to the images of people falling to their deaths from the Towers on 9/11.
#731059 by kered
01 Dec 2009, 10:43
Way too close [n]
#731066 by Darren Wheeler
01 Dec 2009, 12:06
What gets me is that all these protesters/action groups keep popping up all over the world. Last time I checked, there are no Atlantic tunnels and overland to Asia is a bit of a jaunt. Wouldn't have flow by any chance????
Also, why don't they ever go to China and protest about their CO2 output?
#731075 by Decker
01 Dec 2009, 13:27
Bill
OK - I can see that someone might be capable of making that logical leap. I' a simple soul and can't deconstruct to save my life. That would never have occurred to me. So basically any living thing falling from a height in a city which looks a bit like New York would make people think of 9/11. You don't need volition, collapsing buildings, terrorism or crashed airplanes?
#731081 by kered
01 Dec 2009, 15:05
Well the very second I saw the first reflection in the window, of what turned out to be a bear falling, I drew a parallel to those images from 9/11 [:(]
A parallel I could not shake as I continued to watch the video, with the sounds & sights of the bears thumping to the ground combined with the sounds of the aircraft.
All in very poor taste IMHO [V]
#731096 by Sealink
01 Dec 2009, 18:49
I also made no link to 11th September 2001 until someone pointed it out, and even then, I still can't really see it.
#731106 by Decker
01 Dec 2009, 20:08
Yes but polar bear rugs are about 6 times more expensive that black bear rugs... quite a premium. Can you check the price tag next time you're wandering past?
#731107 by Guest
01 Dec 2009, 20:13
Ofcourse !
But you may like to know that there ia a hairdressers next door that may be able to peroxide the black one for you at a fraction of the cost of a polar bear [:w]
#731115 by Howard Long
01 Dec 2009, 22:08
Interesting arithmetic, foiled only by schoolboy error on their dimensions.
I don't see how a 400kg polar bear = 400kg CO2?
Anyway, rather than using patronising illustrations like this, they would be better placed by giving cold hard facts, and put them into perspective, like:
A single passenger taking a return transatlantic flight produces about 1/3 of the average person's entire annual CO2 emissions. [Source http://www.inference.phy.cam.ac.uk/withouthotair/c1/page_16.shtml]
Cheers, Howard
#731118 by Decker
01 Dec 2009, 22:23
Cyclic redundancy check... doesn't the average person take one transatlantic flight a year? [:w] [;)]
#731119 by Howard Long
01 Dec 2009, 22:35
On this forum, certainly... although I don't think that we are necessarily representative of the 5-6 billion other people on the planet.
Cheers, H
#731125 by Darren Wheeler
02 Dec 2009, 00:13
What about all the extra CO2 it took to create the visual effects? All adds up you know.
#731127 by n/a
02 Dec 2009, 00:21
A fact which the world would no doubt cheer [:w]
GJ
#731137 by Bill S
02 Dec 2009, 01:46
Cheers, Howard
CO2 emission calculations for air travel can be quite interesting.
One on the most complex models, trx, is described here.
It allows calculation based on figures for specific airlines including VS.
For example LHR-JFK-LHR by VS in Y produces 1494lbs (calculate here)
For the same flight by BA you produce 1996lbs!
Both are very different from the figures suggested in Howard's reference above of 2 tonnes - 4480lbs!!!
In addition, the Trx calculation above includes radiative forcing, a controversial issue, which has multiplied the emissions by a factor of 2.7
Trx allow this to be switched off bringing the VS return transatlantic emission down to only 554lbs, less than 1/4 tonne.
Now lets consider Polar Bears!
Say their breath contains around 4.5% CO2 - same as us......
a few more calculations ....(which I won't bore you with unless someone wishes to PM me!)
A Polar Bear emits up to 2000lb CO2 per year.
So Plane Stupid is probably right in suggesting we should kill off numerous Polar Bears!
#731143 by slinky09
02 Dec 2009, 10:33
Ohh, geeky and interesting. I see they allocate the CO2 effect of freight to passengers too, at 20% of the passenger value! And they're using 2006 load factors whereas there's lots of evidence that in 2009 they are higher, and they use linear calculations of fuel burn per flight length when we know that take-off is the highest use of fuel and a longer flight will not have a linearly related fuel burn, we could go on (oh and really you should subtract the CO2 emissions created just by 'being') ... in reality it's even less than you described?
Users browsing this forum: Google [Bot] and 6 guests
