#830351 by clarkeysntfc
15 Nov 2012, 09:56
Hello, I'm about to 'press go' on a booking and just wanted to double check the connecting flight with you knowledgable people!
We'd be flying TPA-EWR-LHR with United and then the VS2. Its all booked via VS so a protected connection.
The connecting time at EWR is 2h 12mins to be precise. I understand that United use terminal C but VS is B, and like at JFK we'd have to exit the terminal, ride the monorail and reclear security in B.
I'd be very grateful for any advice on whether this connection sounds sensible?
#830437 by at240
16 Nov 2012, 14:47
Yes I saw that -- think you made the right choice as EWR is a bit grim!
If you misconnect then presumably you'll be shunted off to a hotel and put on the 18 the following morning, which is not a bad outcome!
#830440 by clarkeysntfc
16 Nov 2012, 15:47
at240 wrote:Yes I saw that -- think you made the right choice as EWR is a bit grim!
Indeed it would be, if that did happen :-)
Out of interest, does anyone know if UA would be able to print our BP's for the VS flight at Tampa?
