This is a Trip Report from the Premium Economy cabin
Note that it leaves from terminal 2 at LAS, at which there are few facilities, if you need some food and bits, may well be worth walking over to T1, which has some more facilities.
Anyway once checked in and through there is a nice bar which was across from the departure gate, and they even ask for your ID regardless of your age......
Fly as I mentioned before quiet empty, and this plane was fitted with a slightly newer IFE, which was much better than the outbound plane. Crew again very good, a glass of orange before the flight took off, and then quick service of the meal, and then blinds down, and lights out so we could all get some sleep. Couldn't quite get comfortable in the seat, but managed a few hours anyway, arrived into LGW slightly ahead of schedule, and then off for the long, long walk to passport control, and off home.
Again a good flight, but check on the loads before upgrading, as if they are light, you may get a better sleep on 3 ecnomy seats.
