If it's operated by delta then no it won't be a virgin aircraft
Because when you go to seat selection it takes you to the virgin website.
Friend wrote:Hi does anybody know if the 9:00am flight From gatwick to vegas operated by delta is a virgin aircraft ? Thanks.
If its from Gatwick then its a VS aircraft. Although Delta and Virgin codeshare at Gatwick, Delta aircraft no longer fly there.
There is no flight to Las Vegas from Gatwick at 09:10. Virgin's flight to Vegas, VS43, departs 11:20. It codeshares with Delta, DL4394.
Vegascrazy wrote:There is no flight to Las Vegas from Gatwick at 09:10. Virgin's flight to Vegas, VS43, departs 11:20. It codeshares with Delta, DL4394.
There is a flight at that time from Gatwick to vegas I am booked on it.
As Vegascrazy says, Virgin normally only operate one flight a day from LGW to Vegas, the VS43 which leaves at 11.20.
VS4340 is not a standard Virgin flight number so it must either be an indirect codeshare operated by another airline (not Delta as they don't serve LGW) or a special charter flight.
What date are you booked to fly? How did you book?
http://kvikr.com/flight/vs4340_virgin_atlantic_airways
But it seems to be Anchorage to Minneapolis
All very confusing
gumshoe wrote:As Vegascrazy says, Virgin normally only operate one flight a day from LGW to Vegas, the VS43 which leaves at 11.20.
On my booking it states 09:10 direct to Las Vegas from Lgw booked via Expedia on October the 8th
Friend wrote:gumshoe wrote:As Vegascrazy says, Virgin normally only operate one flight a day from LGW to Vegas, the VS43 which leaves at 11.20.
In the iinterests of trying to get to the bottom of this any chance of posting a pic of the booking ,something is not right somewhere
Blacky1 wrote:Friend wrote:gumshoe wrote:As Vegascrazy says, Virgin normally only operate one flight a day from LGW to Vegas, the VS43 which leaves at 11.20.
Not sure how to post a pic
Searching on Expedia shows a flight option at that time for that date
Also showing on Delta site - as operated by Virgin Atlantic
The flight is VS951..Thursday only?. Plane is showing as a 747-400.
It is bookable via the VS website
MoJoJo wrote:Searching on Expedia shows a flight option at that time for that date
As does searching Delta's iPhone app, which says it is a flight operated by VS - which matches with the VS website showing VS951 operating on that date and time.
adjonline wrote:MoJoJo wrote:Searching on Expedia shows a flight option at that time for that date
How do I upload a pic
Couldn't see an obvious return flight though on Delta site for this plane.
Virgin AU Flyer wrote:Couldn't see an obvious return flight though on Delta site for this plane.
Returning on the 4:35
There doesn't seem to be an extra flight back.... http://i1248.photobucket.com/albums/hh4 ... 531aca.jpg
Is this another epic fail by VS IT? Intrigued as it is showing on the VS website as stated above and the OP has a booking
The only way is left....since I found V-Flyer
4.35 return would be normal Virgin return to LGW
Yeah there's no corresponding return flight as far as I can see. Wonder what VS are up to with that one. Maybe they're operating a charter from that neck of the woods and are taking advantage by running a revenue flight in order to position the aircraft.
Which doesn't make sense as how would all the folks on two outbound fit in one return flight.
