#162258 by Pete
03 Mar 2007, 18:41
Assuming it's not cloudy!
As a lot of you realise, I'm a bit of an eclipse geek, so here's a bit a a background on tonight's Total Lunar.
It will be visible from Greenland to Dubai, with the "main event" between 22:44 to 23:58 GMT. During a total lunar eclipse, expect the moon to go deep-red. If it is clear out there tonight, it should be a good one.
#162264 by Pete
03 Mar 2007, 20:23
Well, the weather looks promising around the Reading area. Just did a test shot, and looking very clear tonight.
[img]/eclipse/moon720.jpg[/img]
Pete
#162267 by tallprawn
03 Mar 2007, 20:56
Great image Pete, keep them coming as the night goes on if possible.
It's cloudy with me so wouldn't mind seeing how the eclipse develops over the course of the evening....:D
#162268 by VS045
03 Mar 2007, 20:58
Clear where I am so fingers crossed that it'll stay like that:)
VS.
#162269 by preiffer
03 Mar 2007, 21:02
Pete - what settings/lens did you use for that?
#162270 by Pete
03 Mar 2007, 21:07
Paul, it's a 70-200L lens at (nearly) max throw, combined with the Canon 2X extender. The EXIF data shows it at 376mm. Aperture is f8, shutter 1/250 at ISO 100. I suspect that I'll probably need to slow down that shutter as the light starts to dim!
#162271 by preiffer
03 Mar 2007, 21:10
Crikey - is that a lens in your pocket or are you just pleased to see me? [:p]
A friend of mine has the 400mm L one for taking photos of him windsurfing from afar, and that's a bitch unless on a tripod or at VERY high speed. Good luck...
#162279 by slinky09
03 Mar 2007, 22:34
Well at 2133 and in SW London the cheese is being eaten!
Hope it's great.
#162280 by Pete
03 Mar 2007, 22:41
Here's a shot as it's really starting to get going properly, taken about 21:35.
[img]/eclipse/moonFirstContact.jpg[/img]
#162281 by slinky09
03 Mar 2007, 22:47
That's great Pete. Bring em on
#162283 by Danno
03 Mar 2007, 23:09
WOW!
Scratch that! Just read the rest of the post about the lens (do tell)..
Dann[:0]
Pete
#162284 by Pete
03 Mar 2007, 23:45
Getting more difficult to keep it sharp, given the length of exposure and the rotation of the Earth (as seen by the small star trail in the bottom right).. but this is just before totality.
[img]/eclipse/preTotal.jpg[/img]
#162285 by Pete
04 Mar 2007, 00:00
Now into totality, and I'm fiddling with ISO & shutter speeds to try and reduce the blurring. Unforunately there's a lot more grain, but you can definately see the red hue now.
[img]/eclipse/totality.jpg[/img]
#162286 by Pete
04 Mar 2007, 00:08
And with a slightly higher ISO to pull out the redness of the moon
[img]/eclipse/totality2.jpg[/img]
#162287 by Pete
04 Mar 2007, 00:20
And now I'm just snapping away for the hell of it...
[img]/eclipse/totality3.jpg[/img]
[img]/eclipse/totality4.jpg[/img]
#162288 by The_Banking_Scot
04 Mar 2007, 00:33
It is a beautiful sight from up here in Scotland ( clear sky also). I can see it from my bedroom window but also going out into the garden.
TBS
#162289 by G-VROY
04 Mar 2007, 00:39
what flights will have the advantage of being 40,000ft closer than us tonight? Great photos by the way![^]
#162290 by Pete
04 Mar 2007, 00:48
And now... just 'cos I like to be arty, here's a composite of tonights total lunar eclipse with last year's total solar, which I photographed from Turkey.
[img]/eclipse/solar-lunar.jpg[/img]
#162291 by honey lamb
04 Mar 2007, 00:57
Looked out just before the eclipse was due to start and there's a big silver moon looking down at me. Got side-tracked with one or two things and remembered just as it was nearing totality. Looked out and it was just as it was in Pete's photo but could not see the redness and at that moment....
.....the clouds rushed in [:(!]
#162292 by preiffer
04 Mar 2007, 00:58
Pete - that's cheating beyond belief! [:0]
But still, looks cool [y]
#162293 by The_Banking_Scot
04 Mar 2007, 01:08
Great pictures pete.
Now coming out of totality with just a sliver of the bright moon visible.
TBS
#162294 by Pete
04 Mar 2007, 01:14
And, in the words of the great Nina Simone ;) Here Comes The Sun
[img]/eclipse/p2.jpg[/img]
#162297 by slinky09
04 Mar 2007, 07:54
Thanks Pete, great snaps.
