#253492 by David
05 Mar 2008, 10:55
Maybe one for Richard.
Have got Vista on a laptop (business edition I think), and taskbar has started to dissappear. I believe this is a problem with IE and if you cancel this in task manager and then restart it, it comes back.
Anyone know if there is there a permanent fix or will this a SP1 fix.
thanks in advance
David.
#437231 by David
05 Mar 2008, 11:44
Hi Richard,
Its explorer.exe that I am ending and then restarting by using file, new task(run) etc.
Media player isn't open. It seems to happen after machine has been left for a while and then unlocked again to restart.
thanks again
#677231 by David
05 Mar 2008, 11:44
Hi Richard,
thanks again
#437234 by mitchja
05 Mar 2008, 12:00
I've just read this morning that IE8 isn't too far way, which might help [:)]
#677234 by mitchja
05 Mar 2008, 12:00
#437246 by RichardMannion
05 Mar 2008, 13:53
There is a developer preview of IE8 due imminently, the consumer/enterprise beta will be later on.
This issue isn't related to IE by the sounds of it, something is hanging Explorer (the shell) which is causing it to end. If you end Explorer, then you lose your taskbar and general front-end.
SP1 is due imminently too for the general masses, it is available for certain technical audiences now.
Richard
#677246 by RichardMannion
05 Mar 2008, 13:53
Richard
