#257203 by nevadakaz
10 Dec 2008, 23:55
With XP, I used to have a USB symbol on my taskbar where you could remove a USB device, then unplug it.
On Vista i can not find such a way of removing a USB device, can anybody advise on how to do this ?
T.I.A
#701966 by locutus
11 Dec 2008, 00:01
It appears on my PC. Have you opened all the taskbar icons fully? It's often hidden.
#701967 by Darren Wheeler
11 Dec 2008, 00:01
Just pull it out. 18months on from first install of Vista, no BSOD and no issues.
#701981 by HighFlyer
11 Dec 2008, 11:17
quote:Originally posted by Darren Wheeler
Just pull it out
Admittedly, I do that too, and I havent ever lost any data ... yet! [:D]
#701982 by Slipperman
11 Dec 2008, 11:23
Right click on the task bar and select properties. Under 'notification area' tab click on customise in the 'icon' section. Hopefully, you will see it under the list for 'past items'.
If not you could always create a shortcut to this command
RunDll32.exe shell32.dll,Control_RunDLL hotplug.dll
Mind you as Darren says, you shouldn't have any issue just pulling it out (as long as any accessing has completed)
#701984 by Decker
11 Dec 2008, 11:33
Just ensure write behind caching is disabled.
