#259233 by phantomtwin
18 May 2009, 20:56
Evening - hoping someone can suggest a PCI Express graphic card for me.
I'm looking for a silent (no fan) graphic card that will support x 2 monitors.
Non gaming use, so the spec does not need to be that high, use will just be general pc stuff.
Keen to understand how twin monitors work (this for an XP machine) so any suggestions/help welcomed.
Andrew
thanks
#715567 by Nevil30
20 May 2009, 16:33
Most graphic cards these days come with 2 outputs often with a DVI and SVGA to which you can connect 2 monitors (You usually get a DVI to SVGA converter in the box) allowing you to dual screen ie spread your desktop across both monitors. I have been doing this for many years at work with the main problem being around compatibility of the applications, for instance when running word or excel you might find that any dialog boxes that appear might appear in say screen 1 but the word/excel document is in screen 2.
I have seen quite a few problems when running Citrix applications in dual screen mode but other than that, when programming for instance, it is a godsend.
Nevil
#715571 by Scrooge
20 May 2009, 17:43
There is a company called Sparkle that makes a line of Nvida based cards that are fanless.
#715831 by phantomtwin
22 May 2009, 21:57
thanks all for the responses...
the Asus looks just the job!
rgds
Andrew
