#16307 by buck3y3nut
16 Nov 2006, 17:25
Guys,
I have a few questions.
First my itinerary:
Dec. 6: JFK - LHR (VS 46)
Dec. 7: LHR - BOM (VS 350)
Jan. 4: BOM - DEL (IC 809)
Jan. 4: DEL - LHR (BA 256)
Jan. 4: LHR - JFK (VS 25)
All of these flights are one 1 ticket issued by VS. This was originally booked on VS/BD; however due to cancellations on the LHR-BOM routes, I was re-accommodated. And VS will re-issue the tickets. It's also under one PNR.
My questions:
1. Will my bags be checked in through BOM on my outbound flight?
2. Will I have a boarding pass for my LHR-BOM flight?
3. Will I have to check-in again at T3 since I will leave the airport and go into the city.
4. On my return, when I check in at DEL, will my bags be checked through to JFK?
5. My BA flight lands at 4:40 (barring any delays) and my VS flight leaves at 6:00 pm. Is that enough time to get me from T4 to T3? (I'm assuming that I will not make this connection if I have re-check my bags. I think I'll be pushing my luck even if my bags are checked in through to JFK)
Thanking You
buck3y3nut
#147993 by Strawberry Muppet
17 Nov 2006, 01:21
I don't know the definite answers to your first two questions.
If your luggage is through-checked to BOM on VS46/VS350 but you don't receive the onward boarding pass then, as your plan is to visit London anyway, just pick up the onward BP at the VS check-in in T3.
If your bags aren't through-checked to your final destination then you will need to check-in again.
BA's policy is to interline luggage to other oneworld carriers only. On your return, it is possible that BA will interline your luggage to VS but this isn't guaranteed. I would suggest you explain to the check-in agent that you have a very tight connection at LHR which you will not be able to make if your bags aren't through-checked. You will definitely not make the VS connection if your bags are only checked through to LHR. Having one PNR may be in your favour.
#147994 by HighFlyer
17 Nov 2006, 01:28
For VS, if your flights are all on the same ticket, you will be able to interline your bags. See here for further details.
#148002 by buck3y3nut
17 Nov 2006, 04:20
Thank you for your help Sarah... They are all on one PNR. Hopefully everything will work out and there won't be too many hassles for me...
