#259379 by jwhite9185
29 May 2009, 18:14
Just used online check in for the first time and had a couple of questions:
Last year when i checked in the old fashioned way, i was given fast track through security - will i get given this again as ive printed my own boarding pass?
Also, when i go to the bag drop is there a separate area for PE customers - and if not then will there be anybody to put the PE tags on my bag. Dont want to spend hours at the other end waiting at baggage claim!
And if the bag drop is really busy, can i go to the PE checkin and just drop my bag off?
Thanks!
#716373 by pjh
29 May 2009, 18:30
At LHR there is a bag drop at the PE end of the check in area. Not sure whether it's dedicated to PE though.
#716374 by jwhite9185
29 May 2009, 18:31
Thanks - really should of mentioned im going from LGW though!!
#716376 by Lizz
29 May 2009, 19:08
just go to the one with the shortest queue be it PE or bag drop, they should all have tags for your bags.
#716382 by Neil
29 May 2009, 19:52
Don't worry about having the PE tags on, they do nothing to determine which bin your bags go in. It is all sorted by the bar codes on the baggage tags printed at the airport, not that it seems to work half the time.
If the bag drop desk is busy just use the normal PE desk, you can use either.
With regards to the boarding card, they will probably print you some card ones off anyway, the paper ones aren't the best and often don't work very well. When you drop your bags off just ask for the fast track sticker as you won't just be able to get through with your boarding card stating PE.
#716387 by Lizz
29 May 2009, 20:46
I think the tags may help abit, never flown or anything but given how dopey some baggage handlers are it may be easier for them to see a red or silver label rather than read their screen as to what can it goes in!
#716538 by sparky
01 Jun 2009, 00:01
Jumping on the back of this thread.....
Is there any advantage of Twilight check in as opposed to OLCI?
We have always taken advantage of Twilight check in being located very close to LGW but wondered whether we should still do twilight or if we should do OLCI instead?
#716539 by Lizz
01 Jun 2009, 00:04
personally I'd use twighlight checkin, mainly based on the fact you have a person in front of you and not a computer!
Users browsing this forum: TomW and 16 guests
