#260025 by 747340
24 Jul 2009, 22:19
Would anyone be kind enough to let me know if the following flights are wide open or not.
VS29 on the 17th August
VS30 on the 31st August
Can i also ask you even though i have seats reserved is it correct i can change them if i do OLCI to different seats
Thanks in advance
#721502 by tontybear
24 Jul 2009, 22:50
dont know about the loads but yes you can change your seats at OLCI.
You can change them to any open seats now in 'manage bookings' if you are not happy with your current allocation and then again see if there are any better ones at OLCI
#721503 by Kraken
24 Jul 2009, 22:51
VS29 - 17Aug09
J6 D6 R5 Z1 W9 S9 K0 Y9 B9 L9 M9 Q0 X0 N0
On the seating plan, 6 unallocated in Upper, 1 unallocated in PE & 29 unallocated in Economy. (Out of the seats available pre-OLCI).
VS30 - 31Aug09
J5 D3 R1 Z0 W9 S9 K6 Y9 B9 L9 M9 Q9 X9 N0
On the seating plan, again, 6 unallocated in Upper, 2 unallocated in PE & approx 50 unallocated in Economy.
And finally, yes you can change your already allocated seats when the other 40% (or thereabouts) become available at OLCI.
Hope this helps
James
#721504 by 747340
24 Jul 2009, 22:54
Thank you very much that is very kind of you
Can i upgrade my flight to UC using Airmiles and Money i booked using Miles plus Money
#721517 by Neil
25 Jul 2009, 12:15
M+M fares are not booked in the correct fare bucket for you to upgrade using miles. The only way you will be able to upgrade is with either cash at the airport, or change you fare to an upgradable fare before hand and then use miles to upgrade. Of course all this is depending on there being G fares available (if you want to use miles).
#721518 by pjh
25 Jul 2009, 12:23
I pre-allocated mine a few months back into 78 and 79 as the entire forward section with our favourite 73 and 74 was greyed out as unavailable, and then up until this morning couldn't make any change. At OLCI this morning I found I'd been shifted to rows 73 and 74 with other seats available...sweet.
Users browsing this forum: TomW and 128 guests
