#744361 by FamilyMan
24 Apr 2010, 19:34
Just a quick question.
Our flight from MCO tonight at 19:30 is now delayed (late inbound aircraft) until 22:45.
Are we still required to check-in as if departure is 19:30. Pretty certain that is the case but 5 hours at airport does not really appeal with three kids.
FM
#744365 by buns
24 Apr 2010, 21:21
By no means is this a defiantive answer, but in these challenging times, i would be checking in on time to ensure that I was not off loaded.
There are so many trying to get back to the UK, that I would not wish to loose my place
#744368 by holliefabbabe
24 Apr 2010, 23:52
on that subject i watched 2 747s land at man on friday within 5 mins , it was so odd watching 2 move to stand ,
now if there was 2 flights flying on same route an hour between them both the first was delayed by an hour and a half would the get the other flight no ?
#744374 by tontybear
25 Apr 2010, 11:59
Neil wrote:No, each flight keeps it's original flight number irrespective of the length of delay.
But dont they get an extra letter if more than 24 hours late?
#744375 by Neil
25 Apr 2010, 12:48
Depends. If the flight is cancelled and rescheduled for the next day when that days original flight will also operate then a 1 is added to the front of the cancelled flight number.
#744376 by ukcobra
25 Apr 2010, 13:29
If I get notified of a delayed checkin, I typically re-set the time I should get to the airport.
I've done this a few times with Virgin over the years, it's always best to check with them.
I got a heads up of a delay to the SFO-LHR flight a few years back, and spent the afternoon in Santa Cruz instead. I did get there with 2 hours to go, and I was the last one to check in !
#744421 by FamilyMan
26 Apr 2010, 11:14
Thanks for all the replies.
I checked with VA and they advised to check in based on the revised flight time. We played it cautiously but arrived at the airport at 6:45 for the scheduled 7:30 departure. No problems at all checking in and indeed check in was less busy as a result. Flight departed at 10:30 so still had a wait but nowhere near as long as it could have been.
Since the inbound aircraft was no due until 8:30 we knew it could not be moved back.
FM
Users browsing this forum: No registered users and 39 guests
