#757418 by catsilversword
11 Oct 2010, 15:14
Noticed that you can now check your bags all the way through, if you're flying VS and then connecting with V America. Anyone done this? Problems/ok/wonderful please? Is that baggage allowance any different? Does V America charge for bags as some airlines do?
#757425 by slinky09
11 Oct 2010, 16:02
The joy of connections on one booking is that the highest allowance applies to all sectors.
This change was only recently announced, I haven't seen any comment yet though. Note however that if you are flying into the US and connecting, your bags may be checked through but you'll still have to pick them up and pass through customs before dropping them off with VA.
#757435 by locutus
11 Oct 2010, 17:20
Sadly I booked my VX flights before the announcement. Still, I get 2 TPs out of it.
#757483 by pjh
11 Oct 2010, 21:43
catsilversword wrote:Does V America charge for bags as some airlines do?
Certainly if you're booking direct. Depends which class you're booked into. "Main Cabin", yes, $25 per bag. "Main Cabin Select" one bag free, $25 per additional bag. "First Class", two bags freed, $25 per additional bag.
#757499 by catsilversword
12 Oct 2010, 05:33
Wonderful - thanks everyone! Only knew about it as I saw it mentioned in the seatbgack mag (and I rarely look at them, so a miracle I saw it!) I barely dare ask if you can make the booking online for all sectors and in one go, or if a call is needed....???
#757502 by honey lamb
12 Oct 2010, 07:28
catsilversword wrote:Wonderful - thanks everyone! Only knew about it as I saw it mentioned in the seatbgack mag (and I rarely look at them, so a miracle I saw it!) I barely dare ask if you can make the booking online for all sectors and in one go, or if a call is needed....???
Why don't you try and do a dummy booking to see if it is possible. If it doesn't work then obviously a call is needed
#757535 by catsilversword
12 Oct 2010, 14:24
Oh, good plan!!!!!!!!!!!!!!!! :) :) :)
Users browsing this forum: No registered users and 160 guests
