#780486 by londonguy
31 May 2011, 15:28
If there is availability on a flight, is it possible to upgrade your seat using miles one-way?
On the Virgin Atlantic flight, I can only find the upgrade amount for a round trip and not for one-way. Is it possible and if so, is it half the miles of a round trip?
Thanks in advance.
#780487 by Luke085
31 May 2011, 15:30
Yes you can, just half it i.e. 10,000 Y to PE 1 way subject to being in the correct fare code, see below:
http://www.virgin-atlantic.com/en/gb/fr ... /index.jsp
#780519 by tontybear
31 May 2011, 17:37
You will also have to pay additional fuel surcharge / APD as well as the miles.
#780528 by ccarmock
31 May 2011, 19:51
I found you can't do this if you booked via an agent rather that direct with VS unless you happened to have ended up in the higher rate for your fare class.
However I did find that if there is availability on the day the upgrade for instance from Economy to Premium at the airport can be from £159, which isn't bad. I managed to do this recently as the miles option wasn't available for a B fare to PE when the B was booked through a travel agent, but was able to pay for the upgrade.
Users browsing this forum: No registered users and 158 guests
