#785493 by mytravelsnaps
10 Jul 2011, 01:05
Hi everyone, just wonder can i change my PE face K ticket to Fare S ticket? so i can upgrade to UC or if i wanna change my date is more availability in S face, many thanks
Tez
#785495 by buns
10 Jul 2011, 07:15
Hi Tez and welcome to V-Flyer
It will be perfectly possible to upgrade your K PE fare to S and a call to Flying Club will provide you with the cost - which might come as a bit of a shock :0
#785498 by pkatmk
10 Jul 2011, 12:14
You can also do this at the airport (I have several times)ie if there is UC availability you pay for two upgrades: from K to S and then from S to G. From memory this has worked out at about £1000 in total for LHR/LAX.
Addendum: Just checked: Actually I paid £688 to LAX and £449 return from Boston for K to S upgrade, then used miles to upgrade to G. On reflection the £1000 referred to above was for a straight S to G upgrade.
#785500 by Osy
10 Jul 2011, 13:46
I have been stung by the K to S cost before at the airport in order to use miles for a UC upgrade. For HKG to LHR one way was I think it was around £350, then the 20K for the upgrade.
Whilst on the flight I realised there might have been a better way! Swapping the PE K fare for an economy Y fare might have earnt a refund, then spend 30K miles for the upgrade? If you have the miles that might be worth a try?
Anyone see any downsides to that?
#785511 by tontybear
10 Jul 2011, 16:00
Osy wrote:I have been stung by the K to S cost before at the airport in order to use miles for a UC upgrade. For HKG to LHR one way was I think it was around £350, then the 20K for the upgrade.
As a K is unchangeable you could not have swapped it for a an economy Y fare to then upgrade. Plus you would have had to fay the additonal fuel surcharge too,
BTW you were not 'stung' by having to pay to change your K to an S to be able to use miles. It is the difference between the twe fares. If you had bought an S in the first place it would have been more than the K. 20k miles is the standard to upgrade from PE to UC, Thems the rules !
#785569 by Osy
11 Jul 2011, 12:19
I guess 'stung' is relative. I agree that was the fare difference for K to S. For me though, I'm usually paying to make an economy fare upgradeable at the desk, which seems to be around the £200 mark, so £350 felt painful given the ticket had been more expensive to start with (as it was for PE).
But I take your point that the fee was totally legitimate.
Thanks too for clarifying that my downgrade idea would have failed.
#785575 by JamesH
11 Jul 2011, 12:57
Quick question tagging on to this topic, my outer flight to LAX is Upper and return is PE. However I wont have enough miles to upgrade until after the outward flight, so could I change from a K TO S and then upgrade with miles even though I have already completed part of the journey?
#785588 by Neil
11 Jul 2011, 15:10
JamesH wrote:
mitchja wrote:There would need to be both S and G availability on the return flight though.
How could I find that out?
By either calling FC, or looking on the VS website.
You can search for G reward fares by doing a dummy miles booking.
You can search for S fares by using using this page on the VS site.
#789759 by Neil
31 Aug 2011, 11:16
JamesH wrote:What is the usual k to s price on the lax route and how do I do this , do I call the flying club ?
It varies, so the best thing to do is call FC to get an exact price.
#789763 by JCBR
31 Aug 2011, 11:31
S fare requires either a 7 day or 21 day advance purchase. If you are less than those then you will end up paying a W fare.
I would think that if you want to pay up at the airport there will be no advance purchase therefore you will pay full W fare.
#789764 by Neil
31 Aug 2011, 11:43
JCBR wrote:S fare requires either a 7 day or 21 day advance purchase. If you are less than those then you will end up paying a W fare.
Unless they have any 'on the day deals' which then make fare codes irrelevant.
Users browsing this forum: No registered users and 184 guests
