#855161 by sherwin
22 Aug 2013, 09:03
hi all
i was just wondering if anyone knows what aircraft will be doing the vs 75 route in oct 2013, if it's an airbus or a 747.
the manage my booking page on virgin atlantic is not currently showing the plane config so i have no idea
thanks
#855164 by slinky09
22 Aug 2013, 09:18
Do you have a date in mind? It's showing an A333 for 9 October for example - but operationally things can quickly change.
#855165 by gfonk
22 Aug 2013, 09:19
sometimes my MMB has days when it doesnt show any config so keep checking.
According the which aircraft tool it is most likely to be an A330. G-VKSS or G-VSXY.
#855169 by Neil
22 Aug 2013, 09:43
gfonk wrote:sometimes my MMB has days when it doesnt show any config so keep checking.
That is just historic data though. As mentioned above, MAN is changing to 2 x 747's from 1 x A330 & 1 x 747 from the winter season, so using historic data won't help the OP.
If the OP can let us have the dates, you will be able to try and new booking on the VS site and it should show the a/c config there.
#855175 by gfonk
22 Aug 2013, 10:08
B) apologies @sherwin.
As Neil and Slinky have asked if you provide the date then we can check for you.
#855372 by stevebrass
23 Aug 2013, 16:56
Showing as an A330 but with UC available. So either a re- configured A330 or a 747.
Still no wiser really!
#855433 by Blackbeard
24 Aug 2013, 10:24
Manage my booking is working for Nov, just booked two 747 UC seats on that fight, they were released this morning for our flight..
#855434 by stevebrass
24 Aug 2013, 10:24
Since afaik there is only a330 in 3 cabin layout I suspect you will be on a 747.
#855438 by Neil
24 Aug 2013, 10:41
stevebrass wrote:Since afaik there is only a330 in 3 cabin layout I suspect you will be on a 747.
SXY and KSS are being reconfigured to the 3 class config.
#855442 by jcc001
24 Aug 2013, 10:58
I am on this flight on 14th Sept. When I try another booking it is showing a 747, however, on my 'Manage my booking' it shows a 330 and to confuse things even more, the seat map is a 747.
I called FC and they confirmed a 747. If this is any different on the 14th I will let you know.
#855455 by stevebrass
24 Aug 2013, 14:04
Indeed they are but I don't know when exactly.
#855508 by gayboyzuk
26 Aug 2013, 09:18
Also flying on VS75 on the 9th October and have booked 3 seats in UC and its a A330 in manage my booking so looks like it will be a newly configured 3 class
