#923212 by SlimpyJones
29 Jun 2016, 18:26
Had a chat with one of the LGW CH staff a couple of weeks ago about the new one. All she really knew is that it was going to be a little bit bigger size-wise, and that the rock will sadly not be making an appearance, apparently because of worries over children climbing on it and falling off, etc.
#923219 by gumshoe
30 Jun 2016, 12:26
Haha! It's very easy, if you're coming from the South Terminal the corridor that leads to the transit station is next to the main entrance to the rail station.
On arrival at the North Terminal stay on the same level, go inside the terminal and you'll find yourself in the Easyjet bag drop area. Bear right, to the far end of the check-in hall, and you'll see the corridor leading to the Hampton.
In the morning just head up one level from the EZY check-in for VS check-in and security.
#923239 by serenawell
30 Jun 2016, 20:40
We are flying from LGW in March to LAS - looking forward to seeing the new CH.
Bit of a longer walk from the BLOC hotel which we use now, never a bad thing.
#923248 by tontybear
01 Jul 2016, 10:16
Traveller2 wrote:I think North terminal is awful. It's ok for your lucky folk that can use the Clubhouse and V room but for the rest of us poor mortals.......not nice.
As pat of the terminal switch LGW are also making other improvements.
Plus if you want a lounge the #1 is available (and once BA have moved out from it it will return back to 'normal')
