#928548 by Derby Flyer
11 Nov 2016, 15:43
Recently I have been looking for U/C seats to MCO from Man for April. Up to now, they have been around the £3k mark each way, but today, I find a couple of different days at sub £1k, which is lower than PE price :-O . Date is around outbound 3rd April, return around 19th April.
Are these genuine, or likely to get cancelled if booked?
#928551 by gumshoe
11 Nov 2016, 16:03
What exact dates are you seeing that fare?
Outbound on the 3rd, return on the 19th I'm seeing about £2,800 direct (or £1,800 if you connect in ATL on the return).
Coming back a day earlier the direct VS flights drop to about £2,000 return but certainly not sub-£1,000.
Are you sure you're not just looking at the outbound price which is £932 on the 5th?
#928553 by marshy11
11 Nov 2016, 16:11
SlimpyJones wrote:The best I'm finding on those dates is £1,700! Could they have been removed already? Sub-£1k is hugely rare.
I am not sure but I think the OP means sub £1k each way as she makes reference to them previously being "around the £3k mark each way".
Edited to add, now I am re reading your post to wonder if you meant you've found £1.7K each way the lowest?
Confused. I am. :cool:
#928554 by gumshoe
11 Nov 2016, 16:17
Ah ok.
Well if the OP was seeing £3k plus EACH WAY that is truly eye-watering! Presumably a fully flexible J fare.
Out on the 5th back on the 18th is just shy of £1,850 return which isn't bad actually. £1,700-ish if you connect via ATL on the way back.
#928555 by Derby Flyer
11 Nov 2016, 16:30
Hi All
Just to clarify.
Outbound 3rd April VS075 - Economy (£589.84), PE (£1049.34) and U/C (£932.34)
There are days around these with similar prices for U/C and even lower for 1 stop!!!!
Return on 17th April VS074 - Ecomomy (£496.90), PE (£1227.90) and U/C (£914.90)
#928556 by gumshoe
11 Nov 2016, 16:39
£1,850 is a good but not outstanding UC return fare. I think I'd normally expect a Z fare to be somewhere around the £2,300 mark.
It's not at all uncommon for PE to cost more than UC if the cheapest PE buckets have sold out but the UC ones haven't.
#928557 by Derby Flyer
11 Nov 2016, 16:43
I agree that at £1,850 return it is not outstanding, but I paid around the same in last New Year sale, and this is over the busy Easter period. Also, to re-iterate, the lowest and Flexible have been almost identical prices over the last 3-4 weeks when looking.
