#858536 by catsilversword
28 Sep 2013, 15:42
Adastral wrote:Just for the record, I have a iPad 3 and it's been pretty good. Just the occasional judder especially when an app has started. It was severe after I updated, but cleared by powering off and restarting.
Re facebook, I don't facebook, but as others have said, check the settings / facebook page and remove the account if one is entered. That said I wouldn't put it past facebook to handle remembering logins in a different way...
catsilversword wrote:I recently bought pages and numbers for my ipad. Pages also loaded into my ipad mini, but numbers hasn't, though it hangs there. Any ideas why? Also, I thought any data input should sync across both bits of kit, but again, this hasn't happened. What am I doing wrong?
To sync, go into settings, then iCloud and make sure you have set up iCloud with your Apple ID. And make sure documents is turned ON.
Then go to the settings page for pages, and make sure iCloud is turned on here aswell. Probably the same for numbers.
If numbers is stuck loading, uninstall it, power off, power on, then reinstall. (You won't have to pay again)
Thanks, will try that!
