#69035 by Wolves27
11 Jul 2005, 11:25
Downloaded it fine.
Fantastic! Managed to make out my block we stayed at at the Wyndham Orlando Resort. You can even make out Dennys just down the road!
Most of the UK is still a bit rubbish though, Wolverhampton nis just a blur if you go in close, sure it'll get better with time.
dean
#69088 by VS045
11 Jul 2005, 21:17
I just downloaded it!
The american maps are great, but the british ones are not so good.
VS045
#69109 by sunny
11 Jul 2005, 22:10
How do you find out how much you have downloaded. I've looked in the Network Connections area and is it the amount of packets?
I'm using Windows XP Pro.
Max
#69111 by DavidM
11 Jul 2005, 22:20
Hi, Sunny - it depends how your system is configured. If you are connecting directly through a modem (that is, not over a LAN), then you will probably see an image of a pair of terminals in your system tray which glow blue when active. If you double click on them, you should get the incoming and outgoing data volume. If there is no icon in the system tray you can switch it on through the properties for your connection, which is in network connections.
#69113 by sunny
11 Jul 2005, 22:29
Hi David
I use cable broadband from telewest - are the procedures the same?
Max
#69114 by sunny
11 Jul 2005, 22:31
I got to the network connections box but it only displays packets.
Max
#69115 by DavidM
11 Jul 2005, 22:59
Max - I've not used cable, so I'm flying blind. In network connections, right-click your default connection to the net, and select the "General" tab. At the bottom of the window there should be a box marked "Show icon in notification area when connected" if the box does not have a tick in it, then click on it (which should produce one). Click OK. Now look at the bottom right hand corner of your screem where you'll find the system tray. If there is not the icon for the connection (you can check by putting the cursor over it, and a small box describing it will appear), then re-start your computer to implement the changes you've made. Now look again and, if there is an icon, double click it. You should then get a window giving incoming and outgoing data volumes. There are various other ways of doing this but, not being sat at your machine, it's difficult to offer a diagnosis from afar. Others may be able to help further.
Hope you get there!
#69132 by anteo
12 Jul 2005, 02:33
Love this :D
MAN is covered in fantastic quality but LHR is awfull!
AND I thought the maps in MS flight Sim were good!
#69155 by sunny
12 Jul 2005, 10:51
Hi David,
All OK now[:I]. Thanks a lot;).
Max
#73930 by DavidM
21 Aug 2005, 10:14
I thought I'd resurrect this topic to give Google Earth aficionados a small giggle at the newest product.
Google Moon is here, and will answer the eternal question about the moon if you zoom all the way in to the highest level of detail :D
Best wishes
#74085 by Scrooge
22 Aug 2005, 23:12
thats funny:D
#74174 by Jonathan
23 Aug 2005, 16:38
Quick question - how frequently are the images refreshed?
#74198 by preiffer
23 Aug 2005, 17:51
Not very often - the Wynn site @ LAS is still the remains of the previous demolition in the current version - so a few years ago at least...!
#75788 by Nitrox
04 Sep 2005, 13:13
Just been looking at SYD airport; me thinks that is a VS 346 on stand (up near runway 16 R) What do ya reckon ?!! :D[8D]
#75790 by mitchja
04 Sep 2005, 13:54
Yeah I think you are right, what with the red engines, red section on the tail with what looks like the purple stripe in front too. It also looks long enough to be an A346....well spotted Nitrox :)
Edit - if you use the measure tool the A/C is the right lengh to be an A346 as well (~75m long)
#75805 by DavidM
04 Sep 2005, 15:32
OK, that's an interesting find, but too easy :D
How about identifying the airline of the landing aircraft at:
51 deg 28' 32.13" North
0 deg 14' 21.53" West
Slightly more difficult!
I would put the .kmz file in this post if I could find a way of doing it. It's only a few bytes, and it provides all the reference information needed to take you to the exact view of the exact location that it's set up for. Anyone know if it's possible to include such a file in a forum post?
Best wishes
#75825 by Nitrox
04 Sep 2005, 18:13
Nah, that's too hard ! Too blurred for my eyes ! Nicely lined up though.
#79947 by webdes03
06 Oct 2005, 16:39
Several VS aircraft on stand at LHR.
Lat: 51¡28'23.29"N
Lon: 0¡27'56.56"W
#80190 by jamie
08 Oct 2005, 13:42
Also a VS346 at NRT
#80465 by ChuckC
11 Oct 2005, 14:28
Found my car in its parking space at the office!
Chuck-
#88724 by Nottingham Nick
27 Dec 2005, 19:19
Thanks to A.Net, I have found this link.
It is an 'add in' that gives real time inbound plane movements to BOS LAX ORD JFK and ATL airports.
It is simple to install and it runs with Google Earth.
#88743 by DavidM
27 Dec 2005, 21:33
Nick - that is a great find. It's fascinating to watch in real time. Thanks for the link!
Best wishes
#88747 by DavidM
27 Dec 2005, 22:06
Nick - I've just played with that add-in a little more, connecting it with real-time JFK ATC Tower radio that you can get here. It takes a few minutes to connect the incoming flights with the voice traffic, but the anorak in me loves it when it all connects.
Worth a play [y]
Best wishes
Users browsing this forum: Google [Bot] and 3 guests
